Question on ohm loads...
inm
How do you calculate how much power you're getting at certain Ohm ratings?
Like, if I had an amp that does 1600 @ 1Ohm, 1100 @ 2ohm, and 500 @ 4 ohm, how much power would it be pushing at 1.33 ohm or 3 ohm?
Would I just kinda of estimate how much power it's pushing, or is there an actual mathematical equation I can use?
Thanks...
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
2008 Subaru Forester XT
its called clamping. get a clamp meter and a dmm, to get actual power output, take whatever (i believe AC amps)amps you're getting from speaker wires x ac volts that will give you your true reading, but you want estimates.. 1.3 should fall around 1300 and 3 ohms probably around 750
The only real way to know how much you are really getting is by "clamping" your system using a DMM and a clamp meter to measure the impedance rise...
Well, I just want an estimate, an equation I can use for while I'm shopping for a new amp... Just to get an idea of what kind of power I'll be seeing at the two Ohm ratings
  • Who's Online   0 Members, 0 Anonymous, 716 Guests (See full list)
