LsChevy Posted April 20, 2011 Report Posted April 20, 2011 I installed 90% of my system with the two batts in the back and i have a few questions. 1. my subs are dual 1 ohm can i wire each to .5 ohm from each terminal on the enclosure to have a end result of 1 ohm at the amp? 2. when grounding the two batts in the back and i ground them to and metal part or the car. (i have to ground them to each side of the trunk) 3. can i ground both batts on the same plane? 4. i put the two main fuses in just to see of the amp will turn on...no luck. does everything has to be grounded and connected before the amp turn on? 5. i attached the remote wire to the blue wire with the white line that's coming from the harness..is that good enough? 6. my hu have one sub out put but my amp have two do i run the"Y" to both "out put" connectors to one of the terminals on the rca's and the two "input" to the other terminal?
StreetSlappah Posted April 20, 2011 Report Posted April 20, 2011 Yes to all. Refs-(b.f.) 99vic, WCA Rusty(x3) Nathan@XSPOWER, Ampjunkielikeme, Bread0710, AmiCreations (s.t.) REsLaPz, PandaGT(x2), Keiferacing, Juicemane (t.w.) Powski, Big gil[/center] Build Log http://www.stevemeadedesigns.com/board/topic/77726-sss-celica-dc-buildupdate-611-finished/ 2005 subi STi 380whp 355whp 17" gold bbs 5% tint all around w/sunglare strip JVC dvd double din Knuconceptz 4ga wiring XS Power! Big 3 8" SAv2 d2 1800 audiopipe
corey0928 Posted April 20, 2011 Report Posted April 20, 2011 1 seems wrong. That would make a .25 ohm load at the amp I believe
LsChevy Posted April 20, 2011 Author Report Posted April 20, 2011 1 seems wrong. That would make a .25 ohm load at the amp I believe really???
slim2fattycake Posted April 20, 2011 Report Posted April 20, 2011 parallel each sub to get .5 ohm and then series would get 1 ohm or parallel again for 4 ohm. How are you getting .25 ohm? SPL-Lab REPCar: 1996 Honda Accord F22B1 CoupeSuspension: Megan Racing Full Street Coilover Dampener KitAlternator: DC Power XP 270Batteries: XS Power D5100 & D3100Wiring: KnuKonceptz & 2/0 Welding cableHeadunit: Kenwood KDC-MP642UComponents: Hybrid Audio ClarusAmplifers: Lanzar OPTI250X4Subwoofer: 2 Sundown Audio E8.v2Deadener: Sound Deadener ShowdownSPL Meter: SPL-Lab RTA Pro meterWant an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has the same features? PM me.CA ref: (enellz, 92c1v1c, el_chupo_, Thixx, Kraudio12, SethPhillips, NJack2AF, JamesKarr, ExpoSport, 01 S 10, wgsj_fortvalley, fast306stang, Lakota, blackga, TheLow, adrian1185, the727kid, rudy, sundownz, lmllopez, traksta15, gentlejax, satchel50207, Bigthangs, Goindef154)CACO ref: (extremechevyman67, ghostmechanic, FatBoy2, TheMan007, bdufner, 350zkid, ironb, bmansbach)SSA ref as phi: ( shizzzon, porkchop, onebadmonte, stevemead, TRP, ///M5, denim)SMD ref: (DC Power Rob, Nathan@XSPOWER, Jman08)And then some.
