I am thinking about buying a used (6 months old per member) Kinetik HC200 for $140 shipped. Is this a good deal? What should I request prior to purchasing? Things like a reading with DMM? If so what should it be reading?? I really want to scoop it but want to make sure I am getting a good battery.
2001 Chevy Silverado Ext. cab - Kenwood KIV-BT901 - 2x 12" DC Audio level 3 m2D1 in 4.2 cuft. @29Hz. - DC Audio 2.0k - Alpine Type-X components - US Amps USA-4300x - XS Power D4700 - Bosch 145a alternator
That's a great deal. Ask for pics of resting voltage. A great battery should read between 12.6-12.9
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Thanks Fizz! Anything other than resting voltage?
My hc1800 rest around 12.8v , as fizzy said , over 12.5v should be ok, i love mi kinetiks , i know XS power is a better battery but also a lot more expensive!!
Oh by the way, best friend´s car has a single Hc2000 with a DD m2 and big3 and he doesn´t drop below 12.5v , just saying :)
With that being said... Look at my sig, whats your best guess as to where my voltage would sit at? No big three at the time as I have removed those wires due to complications. Also, I plan to add a 2k amp and probably a 400 watt 4 channel. Would this help when I added those 2 amps?
Well, it really depends on your alternator man, i mean, it´s a 18 years old car, have you measured what´s your current without cranking the system?? my 99 explorer´s alternator was charing at 13.1v , i knew i needed to change that ASAP and that´s what i did, on the other hand, the car i mentioned before it´s from 2005 and it was charging very nice, we only did the big3 and that was pretty much it.
Once again, i would say that depends on the shape of your alternator, if it´s working properly you should be ok with a hc2400 and big3, GET THE BIG3!!! That thing helps A LOT, 0.7v gain for my explorer and 1v for my swift
  • Who's Online   0 Members, 0 Anonymous, 869 Guests (See full list)
