(6) Neo 8's *Rebuild Done* Vid up
once again good start- and it makes sense how you dont want to destroy trunk with subs up
R.I.P!
(Nov-29-2009)
92 explorer
current build
So its 2 seperate boxes?
Like that last one?
thats the only way itll fit. even then its a bitch
You can do it... Your the master of making big things fit in small trunks.... :santa:
As fucked up as that sounds, Do work son.
just ask Brandons girlfriend :ehh: hahaha
anyway
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
before
after
before
after
then this will give you an idea of how itll look
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Looking good bro!
All three fitting in the middle on each side?
i hope so
itll be tight but it should fit
if they dont i can raise the middle one so it sits on tops of the other two
but i shouldnt need to do that
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
so can anyone see the problem??
im gonna have to use a router to fix that but im not sure if itll be enough. any suggestions?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
turn one of the baffles upside down it looks like it will give you just enough clearance maybe
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
  • Who's Online   0 Members, 0 Anonymous, 5587 Guests (See full list)
