Lights dimming...even with Big3, Mechman Alt, and Optima battery...
I have always had horrible experiences with AutoZone testing my alts or starters. The guy even took off the positive connection and tested it; passed. Took off the negative; passed. Their machine is fucked up and made to let it pass so they don't owe you a new part.
/rant
Edited by Awhitewookie
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
just for future reference, your headlights dont dim because they are HID's. they output the same power with 9-16v or whatever your ballast states. ive started my car with my lights on and they didnt even flicker.
You should find out what your voltage is to see if its dropping on a load. But I don't know, check grounds might be a good idea as well
Yeah, I need to redo the grounds going to the amps. That'd probably help! It's the one place, I've always worried about. I think I'm just gonna run a ground through the body down to the frame! So, that way it's solid!
Float mounted IPad Mini playing through Bluetooth
IStreamer for Iphone or Ipad
Rockford Fosgate 3Sixty.3
RE Audio XXX 6.5's in each door with a second set soon to be added to the front doors
Two Rockford T600-4's for the components
Blowthrough with two Sundown SA-8's
RF T1500-bd's for the subs
8000k H.I.D.'s in headlights and fogs
Lifted 2" in front and 2" in back (soon to be installed a Suspension Maxx 1.5" body lift)
17" Ultra Rogue 175's on Nitto Trail Grappler 285/17 70's
Undercover Bedcover
Surco Roof Rack
Five Hella Lights on front bumper
270A Mechman Alternator
Two Optima Yellow Top batteries
Dynamat double layered each door and roof, quadruple layered on back wall, single layered on floor with Second Skin Luxury Liner Pro on top.
i would replace that yellow top with a xs power
Soon...I hope.
Undercover Bedcover
Surco Roof Rack
/rant
Yeah! He didn't even sound like he knew what he was doing! It was pissing me off!
Undercover Bedcover
Surco Roof Rack
See, that's what I thought. Thanks for clearing that up!
Undercover Bedcover
Surco Roof Rack
If all the wiring is right, then you are simply pulling more power then the reserve of the battery and you are seeing alternator charge delay. If you play a sine track like a 45 hz track or whatever your setup peaks at if you know, that way you get some drop, play that. Watch the drop, and in 5-10 seconds the alt should recover the voltage since it is a constant pull in current, when you play music it is dynamic, always changing the output of the amp, so you need battery reserve to take up that delay in the alt.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
Okay, so I redid my ground wire and ran it all the way to the battery! For some reason, I had a little, and I mean very little< bit of alternator whine, so I wired a 0g ground from the alternator bolt to my battery and lo and behold, alternator whine is gone. I'm still getting a very small amount of dimming at full tilt, but it's alot better than it was! Thanks so much AMI for helping. I'm gonna order another battery hopefully in the next week and I should be set!
Undercover Bedcover
Surco Roof Rack
  • Who's Online   2 Members, 0 Anonymous, 1412 Guests (See full list)
