Porting Box Through Arm Rest Hole
how does he have them in there right now?
If they're facing forward then turn them around so they face backwards.
Hammerdown... 1%
In 4th order the tuning of the box is not isn't really chosen by the builder it's mostly chosen mathematically. Determine what frequency you want to be your "roll-off" where the subs will stop responding well.
Use this calculator and enter driver parameters:
http://www.colomar.com/Shavano/4thorder_info.html
I have messed around with the numbers and it always gives me sealed and ported box sizes that are very close to each other in size. What happened to the 2:1 or 3:1 ratio?
Any help here?
Its (2) 12in Kicker Comps
Qts: .427
Fs: 26.5
Vas: 127.65
Big 3 with Yellow Top
I'd do 1 - 1.25 sealed per, and 2 - 3 cubes ported. If you want it to Play low, tune around 44 - 45 hz. With 13 - 14 square inches of port per cube.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
The smaller 2:1 ratio wont be as peaky as the bigger ratios and the 2:1 ratio will load pretty hard coming into the car from the c-pillar
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
Ok thats close to my original plans.
I'm confusing myself now. Do the two subs share the 1.25 cubic feet sealed and share the 3 cubic feet ported? Or do they share the ported and each get their own induvidual 1.25 sealed?
Did that make sense?
I'd probably do closer to 1 cube sealed EACH.
I said, 1 - 1.25 sealed PER ( which is each ) so that's a total of 2 - 2.5 cubes sealed for the pair, and 4 - 6 cubes ported total.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
Oops sorry. My reading skills dun failed me :ehh:=@
Thanks alot :good: I'll start drawing up some plans
