Dont mean to thread jack, but where is the grounding points in that little diagram? It Just seems like the grounds are going from battery to battery then to amps? Shouldnt you ground them babies to metal somewhere?
Current Setup:
Sony CDX-7401UI
2- 12" Alpine TypeR DVC2ohm Subs
Custom ported box
4-American Bass 6.5in SQ-6B Mids
4-Pioneer TS-T15 Tweeters
2-Crunch P1500.1 Mono Amps
2-runs 1/0 GA KnuKonceptz
KnuKonceptz RCA's
1-Stinger SPV44 Battery
Coming soon:
250 Amp Alt
Custom Door Panels
Second Skin Sound Deadner
All in my 1986 Monte Carlo SS!!!
@davewms9605, probably, unless he wants the........ MAGIC SMOKE :lildevil:
Remember, when grounding, metal to metal contact. No paint in between. Larger wire is also preferable. Good luck with the system man.
If I'm goin to hell, I'm going in a HOLDEN!!!
Speed doesn't kill, Its the stopping suddenly that gets you.
Quoted by the one and only Jeremy Clarkson.
Build: A Secret!
Yes, you should run positive to positive and fuse for the wire ( so there is little to no resistance) so 200 to 250 amp fuse within 18" at the battery under the hood and also at the battery in the back. As for your ground, you should ground to the nearest good ground on your body, and or frame. Then fuse your amps according to the fuses that are currently in the amps. Example: 3 40amp fuses you would want a 120 amp fuse maximum.
DONT MIND ME, IM JUST A DISRESPECTFUL PIECE OF SHIT.
The thicker wire is the 1/0, and the skinnier wire is the 4AWG. You basically connect all the positives together, and then all the negatives together
thanks so much!
Don't forget fuse after first battery, another before the second battery, then one on each positive from the rear battery before the amps. :)
Grounding to batteries is actually the most reliable source. Be sure all crimps/solders are perfect.
06 GP GXP
Google Nexus 7 16gb
Rockford Fosgate 3SIXTY.3
*Electrical*
DC Power 320a HP
2 - Juicebox Bananas g31
Stinger SPP2250 rear
Kinetik HC1800 side of wall
Optima Red Top front
Monster Cable 1/0, 2 runs to rear
Monster Cable 1/0 Big 3
2-Rockford Fosgate T1652S's
Rockford Fosgate T400-4
Rockford Fosgate T40001bd (4693rms @1ohm)
4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's
15.2 cubes net tuned @34hz! Walled off
DBdrag official 151.6db @46hz
GXP Build log!:GP GXP Walled
Quality is the sign of a true enthusiast!
Refs: Link to leave more: http://www.stevemead...91#entry1603091
Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0)
Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
yea you dont have to run a neg from the front to the back. just carfully ground the batts to the frame. also "USE FUSES" 16" from the front bat to the back etc..
Edited by Kian
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
yea you dont have to run a neg from the front. just carfully ground the batts to the frame. also "USE FUSES" 16" from the front bat to the back etc..
You are right that you dont have to, but If you plan on running a lot of power I recommend connecting batteries in parallel. Seriously, if you are going big, just do it right the first time.
06 GP GXP
Google Nexus 7 16gb
*Electrical*
DC Power 320a HP
I agree if everything is close together. Like that back portion after the Duralast. Also dont cheap out, buy some nice welding cable or power wire 1/0. Dont worry about making a knot with the wire. www.weldingsupply.com <-- good prices
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
Agreed, My amp grounds to my rear battery are no longer than 24 inches. Keep that in mind as well. I run Monster Cable 400series 1/0. Not as flexible as other brands but it is all copper. As Kian was saying flexibility isnt always the goal of buying wire.
06 GP GXP
Google Nexus 7 16gb
*Electrical*
DC Power 320a HP
  • Who's Online   0 Members, 1 Anonymous, 1959 Guests (See full list)
