mustangs are real hard to mess with
if u check out my build u can see how i got my 15's in the trunk with the seats still in tact (not much trunk though)
its in my sig
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
ive never had mine metered but at most id put it at 135 with my new amp
not sure about tony's though
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
I take it that getting this car to 145+ db's is no easy task
Its extremly hard to get louder than a 145 in this car, it just flex's way to much, if you watch closely in my video the rear window moves about an 1.5" easily, in that video I only have 1200 watts rms.
can it be done? absolutely, but its gonna be a ton of work and you will need a ton of power, and a ton of money, tune the box in the upper 30's, like 39 hzish
the 2-15 settup was tuned to 32hz.
How high did you hit with the Soundstreams, what kind of amp were you using.
I did a 143.3 bassrace @ a show with the hifonics Brutus 1205D @ .5ohms
One last question, and Ill stop annoying you :) Who and where did your car. I want re-do my sound system. But I dont know of any shops that are as familiar with the mustang . Im sure you have seen my car before. Thank you .
http://i22.tinypic.com/122m32w.jpg
http://i23.tinypic.com/14uku3k.jpg
Edited by stang_01
Did a 142.2 with a pair of 10's on 1500 watts in a '01 Stang. Subs rear, port side. The key seems to be a smaller box that will allow the airflow around it and into the cabin, instead of trying to put big subs in it, unless you go the route David did. We haven't had good luck with 12's in the trunk of those generation Mustangs at all. 10's seem to be the way to go.
Edited by stratusrt01
hey Chester, this is the guy with that had the 00 lazr red GT in vacaville, and your not annoying me at all, I have no problem helping out a fellow Stang lover.
I dont have it anymore, gas was killin me I sold it. Im in marysville Ca. are you going to World Finals? if so i will see you there and we can talk about it.
