wiring harness for 09 silverado
i heard that for the 09 silverado you need a special wiring harness for the onstar, is this true? and if so what wiring harness would it be and where would i get it? cause there are a couple different ones but idk which one is the right one
In my 2008 Silverado, I used the PAC OS3. It works flawlessly. Even comes with a turn signal click/door chime module, which IMO doesn't sound right compared to factory, but it's that or nothing. I believe the 2009 takes the PAC OS4, but you might want to check on that to make sure. I got mine from sonicelectronix.com, and it was about $110, but for me, it's well worth it because it retains onstar, door chime, and turn signal clicks. All of which you would lose if you just wired in a head unit.
I hope this helps.
I hope this helps.
yeah that does help thanks a lot man
i used the PAC OS-4 in my 2007 tahoe
may be diffrent since its a 09 but idk
i also used the PAC SWI-PS to keep use of my steering wheel controls
what kind of radio will you be installing? its dependent on that also
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Os4.
Keeps onstar, door chime and bose if equipped
i looked it up for you
you will need the PAC OS-4
http://www.pac-audio.com/productDetails.aspx?ProductId=384&CategoryID=26
and depending on radio brand i can tell you witch module you will need to keep your steering wheel controls
its a jvc kw-nt3hdt, and i thought it came with the steering wheels control module? thanks for all the help man
nope steering wheel module is seperate... i know its sucks to spend this much money just to replace the radio it was hard for me to pay as much as i did for the wiring harness and steering wheel control module
for the jvc radio you will need the PAC SWI-JACK
http://www.pac-audio.com/productDetails.aspx?ProductId=207&CategoryID=29
didnt read the posts but your going to need a data retention harness which will cost 100-130$ if i remember right , reason is because of the information that is saved with your stock headunit it still needs to have that box. . without that box your check engine light might come on or something stupid may happen .
