Relyks Posted April 27, 2011 Report Share Posted April 27, 2011 ok when i am trying to get 2.00 cu.ft after displacement on torres calculator i am trying to get the gross volume right? not the net volume? does anyone usually put some type of glue or cocking/mold to make sure there aero ports are sealed? anything anyone would recommend that i can pick up from home depot or lowes to make sure inside my box is nice and sealed? Best screws to use? best glue to use? should i be ok if i let lowes/homedepot make my cuts? and the carpet do yall put on with adhesive , hot glue , or just glue? and last question would a slot port be better then a aero? i have my own opinion on all just seeing what u guys think --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
Azagtoth502 Posted April 27, 2011 Report Share Posted April 27, 2011 Net volume is after it's said & done. Just a basic 1 sub box, white caulk along the edges is fine. Titebond II all you need for glue. Basic long wood screws is fine. Spray adhesive for the carpet. Slot port can be easier to tune, Aero more efficient. pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls Link to comment Share on other sites More sharing options...
Relyks Posted April 27, 2011 Author Report Share Posted April 27, 2011 thank you again --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
CaptainzPlanetz Posted April 27, 2011 Report Share Posted April 27, 2011 Net volume is after it's said & done. Just a basic 1 sub box, white caulk along the edges is fine. Titebond II all you need for glue. Basic long wood screws is fine. Spray adhesive for the carpet. Slot port can be easier to tune, Aero more efficient. Aero port's are pretty easy to tune, plus you can change your tuning without having to rebuild the box... Other things to add is don't be shy with the glue Pre-drill so you don't have any splitting Keep screws away from corners of the box Also pick up a 1" dowl rod or two for bracing. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members. Link to comment Share on other sites More sharing options...
Relyks Posted April 27, 2011 Author Report Share Posted April 27, 2011 last question flex in the box make u lose any sound or pressure? --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
tlee2 Posted April 27, 2011 Report Share Posted April 27, 2011 Home depot makes good ass cuts. The one I go to anyway. I gotta get wood cut to fit in my car since I don't have a truck 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333 Link to comment Share on other sites More sharing options...
fecupe2001 Posted April 27, 2011 Report Share Posted April 27, 2011 last question flex in the box make u lose any sound or pressure? I've seen cases on SPL classes where some flex helps, but for a daily application, no flex is the key my man, sounds cleaner and louder IMO I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/ Link to comment Share on other sites More sharing options...
