Box Building questions.
Relyks
ok when i am trying to get 2.00 cu.ft after displacement on torres calculator i am trying to get the gross volume right? not the net volume?
does anyone usually put some type of glue or cocking/mold to make sure there aero ports are sealed?
anything anyone would recommend that i can pick up from home depot or lowes to make sure inside my box is nice and sealed?
Best screws to use? best glue to use? should i be ok if i let lowes/homedepot make my cuts?
and the carpet do yall put on with adhesive , hot glue , or just glue?
and last question would a slot port be better then a aero?
i have my own opinion on all just seeing what u guys think
Net volume is after it's said & done.
Just a basic 1 sub box, white caulk along the edges is fine.
Titebond II all you need for glue.
Basic long wood screws is fine.
Spray adhesive for the carpet.
Slot port can be easier to tune, Aero more efficient.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
Aero port's are pretty easy to tune, plus you can change your tuning without having to rebuild the box...
Other things to add is don't be shy with the glue
Pre-drill so you don't have any splitting
Keep screws away from corners of the box
Also pick up a 1" dowl rod or two for bracing.
¿ǝɯɐƃ ǝɥʇ
last question flex in the box make u lose any sound or pressure?
I've seen cases on SPL classes where some flex helps, but for a daily application, no flex is the key my man, sounds cleaner and louder IMO :drinks:
  • Who's Online   0 Members, 0 Anonymous, 1523 Guests (See full list)
