I'm putting in a second alt, Just for system purposes. And i'm going to put my stock alt back in. The second alt(300amp Iragi) Is going to be ran to two yellow tops. Am I going to need to fuse the wire that runs from my alt to my batts postive, it's going to be at least 3 or 4 runs of 1/0awg. And am I going to need to fuse the runs going from my batts to my amps? They're only going to be 1' to 3' away from my amps.
i would fuse between the alternator and battery. u dont have to fuse between ur battery and ur amp only because of the internal fusing (i hope u have) in the amp. doesnt hurt though. you should also fuse between batteries otherwise the wire could catch fire due to a short.
i fused between the alt and batt, and from the batt to amp...better safe than sorry and on fire or melted. plus if you compete, fusing is usually required...
i likes me some audio stuff...
Guest MegaloManiac
yes fuse every wire...they all see a huge amount of current so its a must
  • Who's Online   0 Members, 0 Anonymous, 4497 Guests (See full list)
