Monergist Posted April 29, 2011 Report Posted April 29, 2011 I decided to get rid of my EQS, but now one of my monoblocks is louder than the other (both gains are at zero). When the EQS was connected, both amps pushed both subs at the same level (I had ran the subwoofer preout from the HU to the input of the EQS, then an interconnect from the output of the EQS to the input of the first monoblock, then the last interconnect from the first monoblock output to the second monoblock's input). However, without the EQS, when I connect the preout from the head unit to the master amp, it is loud, but when I connect the second interconnect to the slave amp, the slave amp is significantly lower (again, both gains are at 0). Things I've tried so far; Switched between Copy/Master on both amps Made both amps Master Connected preout from HU to one amp at a time (when I connect one amp at a time, either amp plays fine) Disconnected remote gain Tried new RCAs I really want to get rid of the EQS.. I'd hate to have to keep it just to be sure the subs both play at the same level! I was thinking maybe my electrical is inadequate, but if that's the case, how could the amps through the EQS play both subs at the same level, while the two amps on their own struggle? Any advice or suggestions? 1994 Cadillac Fleetwood Brougham Pioneer AVH-P5200BT Hertz Mille MLK-165 Component System Hertz Hi Energy HCX-165, 6.5 Hertz Hi Energy HCX-690 (6x9s) Audison Voce AV K6 Component System Audison VRX 4.300 Audison VRX 2.250 Sundown 4500D SMD 15" XS Power D3400 (under hood) Three XS Power D3100 (trunk) Monster XLN-201 RCAs DC Power Engineering 390XP H/O Alternator
woodzyspl Posted April 29, 2011 Report Posted April 29, 2011 me being a noob and all MAYBE droping rca voltage from one amp to next. thats if some fat guy near me told me right about his setup.. AUSTRALIA do i need say more? HU: some crap pionee AMP: dc 9k @ 18v SUB: 4 elevation audio sqx 12" Battery: 2 neuton power 8200d burp setup for fun 152's soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
BassJunkie Posted April 29, 2011 Report Posted April 29, 2011 Maybe your eq was line driving the signal (not sure what eq you have) the decreased voltage or increased length of how far the power has to travel could be effecting it. My solution would be to try rca splitters which should evenly distribute your rca power 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router.
xstingstreetx87 Posted April 29, 2011 Report Posted April 29, 2011 are all your fuses on both amps the same? Do you have 2 y connecters comming off the head units sub out, and then wired to each amp? That is how I would have it wired, shouldn't have any issues that way. DONT MIND ME, IM JUST A DISRESPECTFUL PIECE OF SHIT.
dwright27 Posted April 29, 2011 Report Posted April 29, 2011 Thro a pair of y splitters on the output from the head unit. 1 male to 2 female. 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
Monergist Posted April 29, 2011 Author Report Posted April 29, 2011 Okay, seems like you're all unanimous about RCA voltage drop. And yes, BassJunkie, my Audio Control EQS does have a built in line driver. (no fuses, stingstreet) If y-splitters evenly distribute the voltage from the HU preouts, will that take me to 2v per channel if I have 4v preouts? That would suck. So the best option would be a line driver, right? 1994 Cadillac Fleetwood Brougham Pioneer AVH-P5200BT Hertz Mille MLK-165 Component System Hertz Hi Energy HCX-165, 6.5 Hertz Hi Energy HCX-690 (6x9s) Audison Voce AV K6 Component System Audison VRX 4.300 Audison VRX 2.250 Sundown 4500D SMD 15" XS Power D3400 (under hood) Three XS Power D3100 (trunk) Monster XLN-201 RCAs DC Power Engineering 390XP H/O Alternator
