when tweeters make a sound like there is someone riping paper does that mean it's blown?
2001 peugeot 106 quicksilver
4 beyma 8''
2 titanium bullet tweeters
1 soundstream ST-T15 custom box made
1 hifonics brutus 2400.1
1 cadence c9 competition 100.4
1 SVR 2000P batterie
0 gauge cadence power wire
145.3 @ 42Hz
More than likely. You running a crossover on the tweeter? If so, its blown.. If not lower frequencies that they can't handle will fuck them up too.
why is that tho i just put the in like yesterday...I didnt run them on an amp i just wired them to my car radio witch had the wires already installed but it didnt have the tweeters so i went and pu some
4 beyma 8''
145.3 @ 42Hz
you wired the tweeters directly to the speaker leads off the headunit??
makos if you did this then you blew the tweeters. you have to wire them to the crossover just like you do with the mid bass speaker.
i havent wired the speakers to the crossovers or the tweeters i just connected them with the speaker wire that wasalready instaled in my car.
4 beyma 8''
145.3 @ 42Hz
You need the crossover makos. You can't wire them safely without it. You most likely blew them. They come with for a reason.
Edited by Kranny
What tweeters are they exactly? Some have built in crossovers. But yes like everyone said , it sounds like you may have blown them.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
i have the RF T1T-S. now how do i fix them if i have blown them.
4 beyma 8''
145.3 @ 42Hz
You fix them by buying new ones.
There is no way to fix it.
Next time do not forget to use the crossover.
Only time where you don't have to use crossovers if you use a amp that has built in crossovers that you have to set manually.
