fmedina Posted May 1, 2011 Author Report Posted May 1, 2011 well any help would help lol just wanna know if its the amp or hu cuz idk where to begin. everything is wired correctly and tuned right Quote
BeatBox Posted May 1, 2011 Report Posted May 1, 2011 (edited) if the rca's are not directly on the back of the deck just wrap the wire around the outside of the rca, tape it and run a small wire to a screw on the deck did this to mine yesterday Edited May 1, 2011 by BeatBox Quote
datmexicankid Posted May 1, 2011 Report Posted May 1, 2011 that way is kinda getto but it works i had the same problem with my kenwood hu check ebay for head unit ground loop isolators i think thats what there called here ill just link you to the one i got cleared it right upMy link check it i bought it cleared it all up it had grounds coming off it makes it more secure so they dont vibrate off or something if u just rap them Quote
fmedina Posted May 1, 2011 Author Report Posted May 1, 2011 if the rca's are not directly on the back of the deck just wrap the wire around the outside of the rca, tape it and run a small wire to a screw on the deck did this to mine yesterday so this should cancel the white noise sound i hear in the background? ill give it a try Quote
rubbernutz1 Posted May 1, 2011 Report Posted May 1, 2011 is it like a low level static hum or is it like engine whining noise? Quote
fmedina Posted May 1, 2011 Author Report Posted May 1, 2011 is it like a low level static hum or is it like engine whining noise? like a low static hum Quote
fmedina Posted June 22, 2011 Author Report Posted June 22, 2011 (edited) Ok guys I know its been a while but I'm still getting the static noise in the background of my mids and highs. I grounded my rcas like suggested. One thing I've noticed is that my aq4x90 gets hot after playing music for a bit. It's grounded to the frame of my trunk with my aq1200 ground too. Edited June 22, 2011 by fmedina Quote
Ray Posted June 22, 2011 Report Posted June 22, 2011 First thing about troubleshooting noise is figuring out what kind of noise you have. Is it constant or vary with eng rpm? Is there noise with the car off but radio on? Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
fmedina Posted June 22, 2011 Author Report Posted June 22, 2011 A constant noise and yes with car off too Quote
Ray Posted June 22, 2011 Report Posted June 22, 2011 Ambient noise. "systen noise" 99% of the time is a component problem. What deck? Model? Line drivers? Preamp? Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
