bass_stalker Posted May 2, 2011 Report Posted May 2, 2011 i need help figuring out if i would have enough electrical for a dc 3.5k and a dc 175.4. i used the Rockford amp wire calculator but im not sure if its correct. from what it says i could use a dc power 280amp alternator to power the system along with a d3400 as a primary battery and a d3100 as a secondary battery. any help would be apprciated JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
412 CVX Posted May 2, 2011 Report Posted May 2, 2011 that seems like enough for a 3.5k IMO. but it's better to be safe than sorry, so maybe a d3100 under the hood instead of the d3400. but i'm no expert. this is where someone else needs to chime in with the correct answer Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
That1Kid Posted May 2, 2011 Report Posted May 2, 2011 You would be cool with that. -98' Ford Expedition (Rest in Peace) -AVH-P3300BT -Crescendo BC5500 -4 18" DC m2 Level 3.
bass_stalker Posted May 2, 2011 Author Report Posted May 2, 2011 this was my idea i was planning on running the 175.4 on the d3400 and running the 3.5k off of the d3100 if it was possible JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
412 CVX Posted May 2, 2011 Report Posted May 2, 2011 this was my idea i was planning on running the 175.4 on the d3400 and running the 3.5k off of the d3100 if it was possible are you running a 2 or 3 batt setup? if you've got the d3400 under the hood and the d3100 in the back, then you link the two and it acts as one big battery. in either case you'd need to link the batteries so they would act like one big battery. then it wouldn't matter which battery you put it on Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
bass_stalker Posted May 2, 2011 Author Report Posted May 2, 2011 this was my idea i was planning on running the 175.4 on the d3400 and running the 3.5k off of the d3100 if it was possible are you running a 2 or 3 batt setup? if you've got the d3400 under the hood and the d3100 in the back, then you link the two and it acts as one big battery. in either case you'd need to link the batteries so they would act like one big battery. then it wouldn't matter which battery you put it on ah ok. im new to the multi battery thing but id like to keep it to two batteries if i can. if i need to ill suck it up and modify my battery-pan to fit the d3100 under the hood and then put another d3100 in the back JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
