New box design / port flaring
mmm nice thing you doing buying the heat gun, but honestly man,you didn´t flare it too much, try opening that thing way more!! :yahoo:
When i am out tomorrow i am going to look for a Larger bowl to flare it more. The way my box is set up if I flare it too much the ports will hit each other. I will take it out a little more, just need a better mold.
06 300C 5.7 Hemi
K&N CAI
JVC KW-AVX640 6.1" DVD
DC Audio 3.5k
6 DC Audio 8"s
6 cubes 8" aero port at 32hrtz
http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
Maybe you could have a port a more inside of the box than the other one so the flares can fit, i tried that on a few testings i did, yes you mess with the airflow and lose some tenths doing that without the flares, but with them, you gain a lot more than not having flares at all :)
in your application...center port is FTL as far as you trying to get louder...also a slot port would probably be better in this instance then the makeshift aeros
James, can you explain why centering the port is FTL and why slot > aero? I just like understanding why. I would think with two subs centering the port would be best, but I know that dosnt mean it's right. Thanks
06 300C 5.7 Hemi
K&N CAI
DC Audio 3.5k
6 DC Audio 8"s
So, I bought a larger bowl and tried it again.... I might take them out a little more still, but this is how it came out.
Still a little uneven, but The flared end expands out to 8".. I ran out of time, and could not find any 6" Connecting rings. I did buy another 6' of 1/0 guage and some nuts and bolts to run the speaker wire through the back of the box. Amp will be relocated soon(I hope), and i will flare the inside of the ports first, until i can get more 6" PVC to make two more flares.
06 300C 5.7 Hemi
K&N CAI
DC Audio 3.5k
6 DC Audio 8"s
Looks WAY better now, on my SPL gains topic my flares ended up looking like shit and uneven, but i still gained A LOT, hope this things help you out to get louder man :)
Did some more work. I have been to many plumbing places in the area to try to get some 6" PVC. Found it at only two places, Home Depot and Lowes. A 2' PVC was $5 cheaper at lowes, but it was green and labeled for sewage use. I dont care. :) Not a single place i found carries 6" connecting rings. But here are some pics
I needed two more flares (2 inside and 2 out)
Flared them out to 8"
For anyone thinking of doing this get a large bowl to start with. It is easier to make them come out nice and even.
Since 6" connecting rings are unavailible, I had to improvise. I took about a 2" scrap piece of the 6" PVC and cut a slit through it, and then fit it over the pipe and used it as a support for the flare and the port
Its a lil ghetto, but holds them in place nicely.
Later this week the amp should be moved to the back of the boxand the inside of the ports should be flared. I have already seen a noticeable gain moving the amp, and a lil more with adding the flares.
06 300C 5.7 Hemi
K&N CAI
DC Audio 3.5k
6 DC Audio 8"s
DUDE!!!! those flares look AWESOME if you ask me, is it louder to your ears now? that should have gained you a few tenths!!
About the "connecting rings" , i understood how you made them, but how does it get the connection without moving?? (fucking english lol) , i mean, you had to use some glue or anything?screws? or it´s just attached without anything else and it doesn´t move? great job!
Nice I like the aero ports. Do you know what your doing on the tl?
99 expedition
Two 15 inch dc audio xls
Ported box tunned to 34 hrtz
Soundstream pcx.2000d(better amp soon)
0 gauge
big three(soon)
Yellow top,(more batts soon)
  • Who's Online   0 Members, 0 Anonymous, 679 Guests (See full list)
