each is a 10" sub, each would be receiving its rms power, each would be in the appropriate box sizes...based on specs alone, which is a better spl sub. im assuming sub one, but im not 100% on my sub spec knowledge...
Mounting Depth 1)6.25" 2)6 "
Mounting Hole Diameter 1)9.25" 2)9.25"
Motor Width 1)6.5" 2)6.25"
Weight 1)19.5lbs 2)20lbs
VC Diameter 1)3" 2)3"
Magnet Weight 1)17.5lbs 2)n/a
Power Handling RMS/Peak 600/1200 600/1200
Impedance D 4ohm or 2 D 4ohm or 2
Sd 1)487.00 cm² 2)310 cm^2
Vas 1)32.10 L 2)31 liters
Cms 1)9.67e-05 m/N 2)n/a
Cas 1)2.29e-07 m^5/N 2)n/a
Mms 1)242.06 g 2)n/a
Fs 1)32.9 Hz 2)26.6 Hz
Bl 1)22.18 2)17.7
Re 1)5.80 ohm 2)2.8 ohm
Le 1)5.06 mH 2)n/a
Qms 1)5.21 2)4.4
Qes 1)0.59 2)0.46
Qts 1)0.53 2)0.42
Xmax 1)22.5 mm 2)18 mm
Sensitivity 1)84.70 dB 2)83.2 dB
Edited by amatt85
i likes me some audio stuff...
from the litte about specs that i know i would say sub one b/c higher fs, higher bl, higher xmax, larger motor....
i would say they are pretty damn close and would probably be more install dependant then driver. i dont see anything that jumps out and screams im louder.
i mean look at tc subs
monster BL figures but alot of other subs with lower bl figures are louder.
id prob go with sub 1 just for shits and giggles thoguh
what subs are these
yea, my SE's sound lovely to me...but i think i might switch to DC when competing time rolls around next season and keep the SEs for another install
i know...i dont think they get enough credit...they are some tough boogers and sound really good too...isnt tommy is running in his truck 'ho problems'...
  • Who's Online   0 Members, 0 Anonymous, 1010 Guests (See full list)
