so which 1 do u suggest? this is my daily drive car... n i like em loud when i need it too :pardon:
HU: Kenwood DDX5034
front stage: Focal 165 v Slim component
back stage: Infiniti 652i
component amp: kenwood 4channel
sub amp: sony mono 800watts peak wired to 2 ohms
subwoofer: 3 12" Kenwood subs (from my old car)
4ft would be ok for the power you have you would probably need it anyway and if you want to take it easy on your electrical system wire the subs bridged at 4ohm
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
i have the dimension here, correct me if its off <_<
box, h:16" w:40" d:15"
port, h:5" w:5 h:12
btw, when u say wire the sub bridge at 4 ohms, wire the subs to 8 ohm then combine them both to get 4 ohms rite?
HU: Kenwood DDX5034
either of the ways you suggested you will get about the same power.
this is what i found for your amp
Dynamic Power Rating (measured at 14.4V):
Bridged Into A 4-Ohm Load: 435 watts x 1
Per Channel Into A 2-Ohm Load: 217 watts x 2
Per Channel Into A 4-Ohm Load: 150 watts x 2
Continuous Power Rating (measured at 13.8V):
Bridged Into A 4-Ohm Load: 400 watts x 1
Per Channel Into A 2-Ohm Load: 200 watts x 2
Per Channel Into A 4-Ohm Load: 100 watts x 2
is it in RMS ?
HU: Kenwood DDX5034
is it in RMS ?
the continuous power rating is
port, h:5" w:5 h:12
yup, each sub in series then parallel to the amp
Edited by sticky
Thanks for the help zayres29 n sticky....
HU: Kenwood DDX5034
will post this simple build as soon as i have the time to do it.... 8)
HU: Kenwood DDX5034
  • Who's Online   0 Members, 0 Anonymous, 2907 Guests (See full list)
