100-watts RMS 8s / $99 each from authorized dealer
200-watts RMS 10s / $115 each from authorized dealer
Frequency range is ~80-5000 Hz on these -- the bottom end crossover point depends largely on how much power is ran to them.
8 ohm coils for large setups where you would be connecting 4 per channel to an SAX-125.2 or SAX-100.4 or 8 per channel on an SAX-200.4
These drivers are extremely light and relatively shallow so will fit in many locations easily and also will not weigh down doors with large quantities of drivers as bad as ferrite drivers.
Standard Madisound grilles should fit them -- we will test it shortly.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Is the 10" motor bigger than the 8?
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
Looks to be about the same from what I can see
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
Quick video... my caption :
"We also measured power to be between ~40 and 80 watts during the video... the camera microphone is distorted badly when close to the speaker so I backed up in the video so you can see distortion is quite low in reality; my hand-held camera simply doesn't have a great microphone on it. I was wearing ear-plugs in the video as it was so loud. Also -- we had no baffle on the driver so some cancellation is present -- on a baffle output will be greater. Obviously we will do more videos later... this one was just the first unit we took out of the box to mess with from production."
I'll get to other questions later.
- Jacob Fuller
Had a few people ask about x-max -- linear x-max by 70% BL is 5mm one-way (10mm p-p) with 12.5mm of total clearance allowed in the motor. The coil can move 11.5mm before exiting the gap so it has a bit of extra clearance in there.
We played for quite some time on our 100.2 bridged on the 10" and had it smell hot and abused the heck out of it... could not thermal the 10" driver. When I cut it down the coil was mint -- so I am very pleased thermally.
The 8" has a smaller coil which is why it is rated lower for reference.
I'll get some more specs up once a few people get them installed :) The plan is to send them in for a better FR graph than what I have now as well done at am American facility.
- Jacob Fuller
http://www.caraudioclassifieds.org/forum/1238679-post9.html
"I have had focal, rainbow,MB quart,and alot of other sets of components and these sound just as good but get ten times louder
If u have never had pa mids they have a slight warmer sound then most car speakers and can sometimes sound really flat and vocally mostly because most pa speaker are designed to be in enclosures. But since Jacob designed these to be ran ib these are perfect for car doors. Once u seperate the rear wave from the front (mounting them in a door) they really cone alive and produce very detailed sound. I have my doors sealed up with sound deadened so I have created a true ib environment for the mids. From what I can tell with xover points the Neo pro naturally drops off around 4500-5k and it does so quickly but most tweets should be able to take over from there easily .... all in all some of the best pa mids I have heard
Edit/Delete Message"
Reviews coming in a bit now.
- Jacob Fuller
i wish they came in a 6inch drive,maybe in the future?
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
Wish the neopro's came in pairs...
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
  • Who's Online   0 Members, 0 Anonymous, 2902 Guests (See full list)
