Relyks Posted May 6, 2011 Report Posted May 6, 2011 ok what should i do next money wise new alternator ( toyota picks ups come with a wimpy 60 amp alternator ) new battery im running a marine boat battery now.. my meter is staying around the low 12v when bass hits and 13.1 volt when running.. AND I NEED MORE ELECTRICAL cause my amp barely can turn half way power before its starting to clip on the dmm... and i know it can do more i want most i can out of my audioque 1200d. --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
Craig28 Posted May 6, 2011 Report Posted May 6, 2011 ok what should i do next money wise new alternator ( toyota picks ups come with a wimpy 60 amp alternator ) new battery im running a marine boat battery now.. my meter is staying around the low 12v when bass hits and 13.1 volt when running.. if i was you id get the alt first so when you get the new bat it doesnt see too low of voltage but if your only seein low 12s it could go either way i guess TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener
Relyks Posted May 6, 2011 Author Report Posted May 6, 2011 ALT it is . --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
bumonskateboard6 Posted May 6, 2011 Report Posted May 6, 2011 How do you tell it's clipping on a DMM? It's 1200wrms I'd change the battery to an XS Power, alternators shouldn't be needed till over 2000wrms on most vehicles. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
Craig28 Posted May 6, 2011 Report Posted May 6, 2011 How do you tell it's clipping on a DMM? It's 1200wrms I'd change the battery to an XS Power, alternators shouldn't be needed till over 2000wrms on most vehicles. aq amps have clip lights TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener
Craig28 Posted May 6, 2011 Report Posted May 6, 2011 ALT it is . hey and adding an alt leave you room to upgrade for more batts if you wanted to TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener
Relyks Posted May 8, 2011 Author Report Posted May 8, 2011 with a 60 amp alternator i dont think just upgrading a battery helps i tried a yellow top optima battery and it did not help.. maybe kept me about .3 volts higher when the bass hits which is like 12.7 no bueno. so im getting a new alternator --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
tlee2 Posted May 8, 2011 Report Posted May 8, 2011 Get a new alt. If its charging at 13.1 its prob on it's last leg 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
tlee2 Posted May 8, 2011 Report Posted May 8, 2011 Double post fail 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
