Guest MegaloManiac
wats your voice coil config?
Yeah like that question matters for his question :rolleyes:
how much power is your amp pushing to the subs now?
http://www.americanproaudio.com/vs-14xx.html
Scroll down the page to VS-1405
vs-1405
TWO CHANNEL BRIDGEABLE AMPLIFIER
MAXIMUM POWER OUTPUT
300W x 2CH (600W) @ 2 OHM
POWER OUTPUT:
130Wx2CH (@ 2OHM) LESS THEN 0.3% THD
80Wx2CH (@ 4OHM) LESS THEN 0.1% THD
MONO: 260Wx1CH (@ 4OHM) LESS THEN 0.3% THD
ALL MEASUREMENTS DONE @ 14.4VDC, 1KHz INPUT SIGNAL
FREQUENCY RESPONSE 20Hz-20KHz
2OHM CAPABLE IN STEREO MODE ONLY
THIS MODEL IS EQUIPED WITH:
LPF (LOW PASS FILTER) VARIABLE 50Hz-250Hz
HPF (HIGH PASS FILTER) VARIABLE 2KHz-10KHz
HIGH AND LOW ADJUSTABLE LEVEL INPUT
MOSFET DC-DC SWITCHING POWER SUPPLY
LED INDICATED POWER STATUS
BUILT IN PROTECTION AGAINST SHORT CIRCUIT AND HIGH TEMP
TRI-MODE SPEAKER CONNECTION READY
BASS BOOST (+5dB @ 100Hz)
AUTO POWER ON/OFF BY REMOTE (+12V)
DIMENSION: 11 1/8 (W) x 1 7/8 (H) x 9 15/16 (L)
Thats the specs on the page
"MY RIDE"
1987 Chevy Cavalier Z24 2.8L V6 -- CB Radio with PA speaker
Head Unit: 7 inch Jensen Flip-out -- Speakers: 4 Visonik 6 1/2s and 4 Visonik 6x9s
Subwoofer: One Audiobahn 18 - Sub Amp: Power Acoustik OV1-2000d 2000 watt monoblock amp --
Battery in back - Kinetic HC600 -- Sub box: Custom built 5 cubic foot tuned to 30 hertz
Coming soon: Bigger Highs Amp, Power inverter
"WhItE bOi AuDiO"
"FEAR THE DUCK"
it does cause he might be able to get another amp for the same price as that.
vs-1405
POWER OUTPUT:
well i would just keep saving and just get something better than the audiobahn.
But see your not answering my question my amp I have is giving the subs what like 60 - 70 watts to each ten. I want to know if the Audiobahn would be louder on which setup the 4 ten's at 4 ohms or the two ten's at 4 ohm?
:huh: :huh: :huh:
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
:huh: :huh: :huh:
i would say the 4 10's
Ok I want some more Opinions or knowledge on which would be louder before I get this amp.
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
Are there anybody else that can tell me which would be louder cause I wan't to hear it from more then one person before I buy this amp.
Just so you know I am not buying this brand new, well its never been hooked up, but I am getting a good deal on it.
Edited by white_boi_audio
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
