http://minornotes.co...erdiagrams.html
go about half way down it will show u 4 single 4 ohm speakers wired to 4 ohms
thanks for that, thats exactly what i need
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
im thinking of adding two small horns now but im wondering if i can wire them to the deck
idk man that might be pushing it let me see what i can find what are the ohm loads on the horns and are u gonna have 1 per side?
they say suited for 4-8 ohm applications so im gussing they are 4 ohm a piece since there are two per set. and if i can run them on the amp ill just run them on the headunit.
hmmm thats your call man i think you should be fine just careful on the tuning
that's what i figured id just have to try to match it as close as i can.
