DannyB Posted May 10, 2011 Report Posted May 10, 2011 Ok so in the past I just install the speakers and dial in 80hz on the amp and 80hz on the head unit. I had an installer tell me the other day 80hz is too low and to go between 150 and 200hz. (These are full range speakers I have now) I am installing new Polk Audio MM6501's Wednesday. I emailed Polk to inquire about this and they recommend the same 80hz. Anyone have an answer on the difference between the two recommendations? Is it a difference in the full range compared to component set? I also have a pair of Focal component that I was told to cross at 80hz. What is working for some of you guys? Thank you 07' 6.7 mega cab H&S mini maxx DPF/EGR delete 5" TBE 4.5" Fabtech 35" nittio trail grapplers 20" BMF novakane's Kenwood KIV-700 Rockford Fosgate T1500-1bdCP 2-MB Quart 4.80 3-Polk Audio MM6501 ProBox DMC212L-1000 144db @45hz Viper 5901
DannyB Posted May 10, 2011 Author Report Posted May 10, 2011 Anyone? 07' 6.7 mega cab H&S mini maxx DPF/EGR delete 5" TBE 4.5" Fabtech 35" nittio trail grapplers 20" BMF novakane's Kenwood KIV-700 Rockford Fosgate T1500-1bdCP 2-MB Quart 4.80 3-Polk Audio MM6501 ProBox DMC212L-1000 144db @45hz Viper 5901
Parentnoia Posted May 10, 2011 Report Posted May 10, 2011 Well I'd think of it this way. My amp doesnt have a variable crossover. I just flip a switch to turn crossover on an off. And the cutoff is 80hz. So I dont really have much choice in that department. But it must be an acceptable level if someone went ahead and set that anyways. 1999 GMC Suburban SLTNo system planned just yet. Look at "hate" spelled backwards. It spells "e-tah." For example, if you hate me you can e-tah dick.
DannyB Posted May 10, 2011 Author Report Posted May 10, 2011 I will use the recommended 80hz from Polk Audio unless someone here can explain to me why some people would cross at 150-200hz. Thanks for the reply Parentnoia, 07' 6.7 mega cab H&S mini maxx DPF/EGR delete 5" TBE 4.5" Fabtech 35" nittio trail grapplers 20" BMF novakane's Kenwood KIV-700 Rockford Fosgate T1500-1bdCP 2-MB Quart 4.80 3-Polk Audio MM6501 ProBox DMC212L-1000 144db @45hz Viper 5901
Rev. Wrath Posted May 10, 2011 Report Posted May 10, 2011 I'm currently running Alpine Type R components, and I have mine crossed at 80 as well. They sound great and I've never had an issue with this setup. The only reason, that I can see, you would ever have to cross at 200 is if you had separate mid-bass drivers.
michigancapri92 Posted May 10, 2011 Report Posted May 10, 2011 ive always used 80hz and i think 80hz is the best sound for me, radio has a HPF setting of 50,63,80,100,125 and i like 80 the best! Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
DannyB Posted May 10, 2011 Author Report Posted May 10, 2011 Thanks for the input guys. 07' 6.7 mega cab H&S mini maxx DPF/EGR delete 5" TBE 4.5" Fabtech 35" nittio trail grapplers 20" BMF novakane's Kenwood KIV-700 Rockford Fosgate T1500-1bdCP 2-MB Quart 4.80 3-Polk Audio MM6501 ProBox DMC212L-1000 144db @45hz Viper 5901
