full size standard cab chevy box ideas
just bought a 92 chevy standard cab and I'm looking for ideas. (besides a blowthrough) I had a tahoe running a single 18 and was pretty happy with that setup.
I debated getting an extended cab but I just like the look of a standard cab shortbed more. I did figure that I could do a blowthrough if all else failed.
the truck has a bench but I'm planning on buckets so the center console is gonna be open. my thought was to make a sort of t shaped box to utilize all the space that I have available.
thoughts and ideas are welcome.
thx
blowthrough it was stupid easy in this truck.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
If you're going to do buckets then put the 15 in the center mounted inverted and use all the area behind the seats for box volume.
Hammerdown... 1%
ReDDrum, Lol. You fail to mention that you have to be a dwarf to drive it........10" forward at the top ofthe back seat doesn't work in the real world. ;)
OP, depends on how much you can move the seat forward. Measure out your available airspace and decide. In those trucks I've done starting at 3-8's ported, seat all the way back to 4-8" or 2-10"'ported seat up a notch or two. It will depend on the depth of your woofer too.
Clovis Custom Audio 559-392-3600
96 Silverado Single Cab
2-DD9515's Cut-through
1-DDSE Amp
Stock electrical and a couple small stingers, LOL
  • Who's Online   1 Member, 0 Anonymous, 1494 Guests (See full list)
