juiced Posted May 10, 2011 Report Share Posted May 10, 2011 just bought a 92 chevy standard cab and I'm looking for ideas. (besides a blowthrough) I had a tahoe running a single 18 and was pretty happy with that setup. I debated getting an extended cab but I just like the look of a standard cab shortbed more. I did figure that I could do a blowthrough if all else failed. the truck has a bench but I'm planning on buckets so the center console is gonna be open. my thought was to make a sort of t shaped box to utilize all the space that I have available. thoughts and ideas are welcome. thx Quote Link to comment Share on other sites More sharing options...
n8ball2013 Posted May 10, 2011 Report Share Posted May 10, 2011 blowthrough it was stupid easy in this truck. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
juiced Posted May 10, 2011 Author Report Share Posted May 10, 2011 was wanting to avoid cutting the truck. want to see how loud I can get with everything inside the cab. Quote Link to comment Share on other sites More sharing options...
ReDDruM Posted May 10, 2011 Report Share Posted May 10, 2011 i did 4 8"s behind the seat in a '89 that does a 146.7 at 29hz at the headrest Quote TEAM BUILT FOR DECIBELS s10 blazer subs:2 Addictive Audio amp:Addictive Audio 500.1 batts:Vital Power vp1500(front), vp2000(rear) Link to comment Share on other sites More sharing options...
juiced Posted May 10, 2011 Author Report Share Posted May 10, 2011 I like the sound of that. do you have a link to the build? Quote Link to comment Share on other sites More sharing options...
ReDDruM Posted May 10, 2011 Report Share Posted May 10, 2011 no build thread Quote TEAM BUILT FOR DECIBELS s10 blazer subs:2 Addictive Audio amp:Addictive Audio 500.1 batts:Vital Power vp1500(front), vp2000(rear) Link to comment Share on other sites More sharing options...
juiced Posted May 10, 2011 Author Report Share Posted May 10, 2011 (edited) what kind of power is goin to each sub? Edited May 11, 2011 by juiced Quote Link to comment Share on other sites More sharing options...
STEvil Posted May 11, 2011 Report Share Posted May 11, 2011 If you're going to do buckets then put the 15 in the center mounted inverted and use all the area behind the seats for box volume. Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
ReDDruM Posted May 11, 2011 Report Share Posted May 11, 2011 what kind of power is goin to each sub? 4-500 each Quote TEAM BUILT FOR DECIBELS s10 blazer subs:2 Addictive Audio amp:Addictive Audio 500.1 batts:Vital Power vp1500(front), vp2000(rear) Link to comment Share on other sites More sharing options...
Reilly Posted May 11, 2011 Report Share Posted May 11, 2011 ReDDrum, Lol. You fail to mention that you have to be a dwarf to drive it........10" forward at the top ofthe back seat doesn't work in the real world. OP, depends on how much you can move the seat forward. Measure out your available airspace and decide. In those trucks I've done starting at 3-8's ported, seat all the way back to 4-8" or 2-10"'ported seat up a notch or two. It will depend on the depth of your woofer too. Quote Clovis Custom Audio 559-392-3600 96 Silverado Single Cab 2-DD9515's Cut-through 1-DDSE Amp Stock electrical and a couple small stingers, LOL Link to comment Share on other sites More sharing options...
