kingsuv Posted October 3, 2007 Report Posted October 3, 2007 Well make sure your not trading for a " box or rocks " if ya know what I mean Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it.
Tkitt21 Posted October 5, 2007 Author Report Posted October 5, 2007 ok I got the kicker solo-baric L7 and I have no idea how to wire it. it has a Coil 1(+.-) and a coil 2 (+,-) how do I wire this iv tried and cant get it to work ~REFS~ -CA.com-Gianotti(2 18" FI BTL D1) Slowd N Throwd(Wiring),Ebrunn(PC monitor),Rab(HK4000D) -SMD.com-Nismofreak(Radar),BigP(Phone Headset),anonymous(Xbox360 Headset)
andym85 Posted October 5, 2007 Report Posted October 5, 2007 depends on what impedance it is (dual 2 or dual 4ohm) and depends on what ur amp is rated for...give more info plz i likes me some audio stuff...
Tkitt21 Posted October 5, 2007 Author Report Posted October 5, 2007 depends on what impedance it is (dual 2 or dual 4ohm) and depends on what ur amp is rated for...give more info plz the sub is 4ohm and my amp is american bass pro (mine is 600watt but it says vs-1404) vs-1404 TWO CHANNEL BRIDGEABLE AMPLIFIER MAXIMUM POWER OUTPUT 200W x 2CH (400W) @ 2 OHM POWER OUTPUT: 85Wx2CH (@ 2OHM) LESS THEN 0.3% THD 55Wx2CH (@ 4OHM) LESS THEN 0.1% THD MONO: 170Wx1CH (@ 4OHM) LESS THEN 0.3% THD ALL MEASUREMENTS DONE @ 14.4VDC, 1KHz INPUT SIGNAL FREQUENCY RESPONSE 20Hz-20KHz 2OHM CAPABLE IN STEREO MODE ONLY THIS MODEL IS EQUIPED WITH: LPF (LOW PASS FILTER) VARIABLE 50Hz-250Hz HPF (HIGH PASS FILTER) VARIABLE 2KHz-10KHz HIGH AND LOW ADJUSTABLE LEVEL INPUT MOSFET DC-DC SWITCHING POWER SUPPLY LED INDICATED POWER STATUS BUILT IN PROTECTION AGAINST SHORT CIRCUIT AND HIGH TEMP TRI-MODE SPEAKER CONNECTION READY BASS BOOST (+5dB @ 100Hz) AUTO POWER ON/OFF BY REMOTE (+12V) DIMENSION: 11 1/8 (W) x 1 7/8 (H) x 8 (L) ~REFS~ -CA.com-Gianotti(2 18" FI BTL D1) Slowd N Throwd(Wiring),Ebrunn(PC monitor),Rab(HK4000D) -SMD.com-Nismofreak(Radar),BigP(Phone Headset),anonymous(Xbox360 Headset)
FieroGrande Posted October 5, 2007 Report Posted October 5, 2007 looks like you need to wire it + to + and - to - on the sub............. that will get you a 2 ohm load.
Tkitt21 Posted October 5, 2007 Author Report Posted October 5, 2007 looks like you need to wire it + to + and - to - on the sub............. that will get you a 2 ohm load. I got it to make a scathcing noise. when I push down on it, it makes a type of scratching noise does this means its blown after i finsih mowing ima run it down to California customs or laws ~REFS~ -CA.com-Gianotti(2 18" FI BTL D1) Slowd N Throwd(Wiring),Ebrunn(PC monitor),Rab(HK4000D) -SMD.com-Nismofreak(Radar),BigP(Phone Headset),anonymous(Xbox360 Headset)
andym85 Posted October 5, 2007 Report Posted October 5, 2007 if u hear a scratching noise when u push down on it that is probably about the coil beind f'd up...sounds like ur screwed... i likes me some audio stuff...
Tkitt21 Posted October 5, 2007 Author Report Posted October 5, 2007 if u hear a scratching noise when u push down on it that is probably about the coil beind f'd up...sounds like ur screwed... He said when we traded that if i didnt like it we could trade back(he said he had never hooked it up but before he had heard it before he bought it. How much does it cost to get fixed? ~REFS~ -CA.com-Gianotti(2 18" FI BTL D1) Slowd N Throwd(Wiring),Ebrunn(PC monitor),Rab(HK4000D) -SMD.com-Nismofreak(Radar),BigP(Phone Headset),anonymous(Xbox360 Headset)
kbreudi Posted October 5, 2007 Report Posted October 5, 2007 He said when we traded that if i didnt like it we could trade back(he said he had never hooked it up but before he had heard it before he bought it. How much does it cost to get fixed?Well if when you push on the cone and hear a scratch that is deff a blown coil....as for the L7's kicker does not sell a recone kit, only the solo X's. I beleive kicker charges $240 to recone a 15" L7 which is about the same price they are new. So i would trade back if not you got a useless sub on your hands. TEAM SUNDOWN 4 Nightshade 15"s 2 Sundown SAZ-4500 8 Deep Cycle batts 1998 Cadillac Catera SPLMAX CUP 2008 Fourth Place Overall
Tkitt21 Posted October 5, 2007 Author Report Posted October 5, 2007 VIDEO ADDED ~REFS~ -CA.com-Gianotti(2 18" FI BTL D1) Slowd N Throwd(Wiring),Ebrunn(PC monitor),Rab(HK4000D) -SMD.com-Nismofreak(Radar),BigP(Phone Headset),anonymous(Xbox360 Headset)
