Heya guys!
I’ve looked into Dcalternators to get a HO alternator. I’ll think about getting Dual brackets kit to run 2 alts including the stock alt. My ride is an Escalde 2003.
270XP : $599 (210A idle)
270SP: $449 (180A idle)
280PRO: $399 (160A idle)
My system is: 3x batt (75Ah Running Bull AGM) all 0 gauge, 2x Rockford t20001bd at 2ohms, SoloX 18”
I see most people get the 270XP. Is there any other significant difference between these alts than the idle output??
I hoped to use a dual alt setup, so maybe it is enough with the 270SP??
peace
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
mainly people get the XP for the high output at idle
with the dual kit, either the 270XP, or 270SP will be fine
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Shit, that XP is expensive! The XP has more idle voltage than DC's other lines. The dual SPs will be MORE than enough. Extra alt current isnt necessarily bad though. It limits/eliminates voltage drop. That means :morepower1:
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
He wants to run the stock alt with the dc power alt
Not two dc alts
Not two dc alts
Reading > me. With around 390amps of charging current when revving, im sure he'll still be fine. He may still be fine at idle with those 3 batts (if theyre really 75a and good).
LMFAO so true
:blush:
I think with the dual alt, stock and any of those DC alts you would be fine. Do you plan to keep the stock alt for just vehicle functions like charging starting battery and maintaining, or do you plan to use both for vehicle and system use simultaneously.
06 GP GXP
Google Nexus 7 16gb
Rockford Fosgate 3SIXTY.3
*Electrical*
DC Power 320a HP
2 - Juicebox Bananas g31
Stinger SPP2250 rear
Kinetik HC1800 side of wall
Optima Red Top front
Monster Cable 1/0, 2 runs to rear
Monster Cable 1/0 Big 3
2-Rockford Fosgate T1652S's
Rockford Fosgate T400-4
Rockford Fosgate T40001bd (4693rms @1ohm)
4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's
15.2 cubes net tuned @34hz! Walled off
DBdrag official 151.6db @46hz
GXP Build log!:GP GXP Walled
Quality is the sign of a true enthusiast!
Refs: Link to leave more: http://www.stevemead...91#entry1603091
Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0)
Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
I plan to run them together, not divided between audio and car function.
It seems better to go for a HO alternator at this point than adding a few extra batteries.. Since this is for daily driving and not indoor demo's...
At least on paper there should be no difference between SP or XP series in output voltage; 14.8V. But experience >>> paper.
You misread my post. I meant that between the alts and batteries, you should be okay at idle.
I thought the XP has a voltage regulator set to 15.1volts. I may be wrong, but im almost positive.
Edited by hdorre
LMFAO so true
:blush:
I guess they might put out 15.1v... I've seen that on youtube videos as the 'regular' resting voltage. I dunno if there are external VCU that easily fits to these alts? (url anyone?)
DC alternators sell the kits clearly stating how they would perform together with stock.
I've never seen or heard about anyone on the forums who has done that. People always tend to go for as many XP's they can fit/afford.
What would happen to the output voltage? The XP' seems to be put at 15.33, probably way higher than stock (and SP's too!). What kind of output do I get when mixing XP and stock?
Plus, I was thinking to do 3 runs of 0 gauge (all positive?), that be enough right?
