Stee-Z Posted May 12, 2011 Report Posted May 12, 2011 I'm not the biggest gain setting fan, but its time to start and learn. Ive done some research, but mostly came out empty handed due to the fact of not fully understanding it. So if anyone could tell me if what I'm saying is true, and where they "should" or are "normally" set at ( I know every system is different, but if you could give me a rough idea that would be great)I am running a 15" HCCA Orion to give you a rough idea. I am mostly doing this forum for the knowledge gain rather then needing help really bad. So any help would be great thanks! Gain-5v-0.15v- I believe i start out at 5V and tune up till it clips Subsonic-10Hz-50-HZ- I believe this tunes out to low of notes, but where should it be at? where my box is tuned like at 30 Hz? Bass Boost- 0DB-6DB I know this makes it hit harder, but where is the usual point where there at, half or 3/4?? LPF-20Hz-200Hz, I believe this makes it lower, or higher, where is this usually tuned? (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
memphisBred Posted May 12, 2011 Report Posted May 12, 2011 Gain is used to fine tune the input voltage. If you have 3.16 volts from the deck you'd want to have the gain at or above 3.16 volts. Easily done with a oscope. Turn subsonic to ~5 Hz below tuning. Bass boost off LPF to around 60-80 depending on preference and where your front stage picks up. SMD Super Seller/Buyer Audison----Hertz----Rainbow
Stee-Z Posted May 12, 2011 Author Report Posted May 12, 2011 ok, im getting most of it, but so you want the bas boost all the way off?? I thought this made it hit harder, or does it more distort it then? (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
dwright27 Posted May 12, 2011 Report Posted May 12, 2011 Your subsonic and lpf will change your output/gain 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
dwright27 Posted May 12, 2011 Report Posted May 12, 2011 ok, im getting most of it, but so you want the bas boost all the way off?? I thought this made it hit harder, or does it more distort it then? Makes it clip and distort faster because it boosts the output voltage 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
Stee-Z Posted May 12, 2011 Author Report Posted May 12, 2011 so leave the bass boost at 0 right? and just control with my bass knob up front? (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
memphisBred Posted May 12, 2011 Report Posted May 12, 2011 Watch a few tutorials on how to set them. It's not as easy as setting the four functions to a estimated point. Setting them with a oscope allows for a perfectly clean signal/system. SMD Super Seller/Buyer Audison----Hertz----Rainbow
Stee-Z Posted May 12, 2011 Author Report Posted May 12, 2011 this should be temporary until Meade releases his distortion listner, i just want to have my system safe until it comes out (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
Stee-Z Posted May 12, 2011 Author Report Posted May 12, 2011 also, a quick question about the Otput Master, and Input slave I should have it onto Input slave right? Isn't Output master when i would link my two amps togethor? (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
