Ray Posted May 12, 2011 Report Share Posted May 12, 2011 Plus you are not getting 3500 after rise and v drop anyway. But......yes..i clamp 3500 on each 8 0.. They hold for a little bit Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
TIG Posted May 12, 2011 Report Share Posted May 12, 2011 im running a aq3500 on a 100 amp fuse on music and it is doing great. I tried it at .5 on 100 and it held up. I say you could damn near run a 40/60 amp fuse. When you burp you do not need to run the sub for 30sec continuous. Only long enough to get your best score. Meca gives you 30 seconds but if you can get your best score in 3 then your good to go. I would try running a 40 and see what it does. S1 is better than S2 and As2 you dont get to run your engine. I dont like the idea of running in that class because of the draw. Quote Since were all having a moment of truth. I hate country too.. I'd only listen to it if I got some hotass bitch in my car and shes gonna suck my dick. Link to comment Share on other sites More sharing options...
IH8PunkRok Posted May 12, 2011 Report Share Posted May 12, 2011 try a 40 amp fuse. get into AS1 highest score atm is a 144.3 in that class mini anl and agu are commonly accepted as strongest. i like agu myself Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build Link to comment Share on other sites More sharing options...
TIG Posted May 12, 2011 Report Share Posted May 12, 2011 (edited) agu seriously? I have never had a good experience with these. I got big amp fuses to malfunction with small power. The solder in them gets hot and causes the fuses to fail. I would go with a mini anl for sure. Meca accepts them. Edit: of course meca accepts them, what the fuck was I thinking haha....Pretty obvious statement. Edited May 12, 2011 by TIG Quote Since were all having a moment of truth. I hate country too.. I'd only listen to it if I got some hotass bitch in my car and shes gonna suck my dick. Link to comment Share on other sites More sharing options...
outsideshot23 Posted May 12, 2011 Report Share Posted May 12, 2011 i was going to ask if it would be better to just burp or slow roll, or fast roll etc... Quote Vote for May SOTM!!!! uild log---------> http://www.stevemeadedesigns.com/board/topic/104017-sierra-on-26s-20000-watts-daily-pics/ Kenwood Excelon HU 4 18" Atomic APX 4 RD D9s 4 DC Power 270xp alts 9 xs d1400 batts Team XSPower Team SecondSkin Link to comment Share on other sites More sharing options...
IH8PunkRok Posted May 12, 2011 Report Share Posted May 12, 2011 agu seriously? I have never had a good experience with these. I got big amp fuses to malfunction with small power. The solder in them gets hot and causes the fuses to fail. I would go with a mini anl for sure. Mecca accepts them ive never had an issue with them Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build Link to comment Share on other sites More sharing options...
TIG Posted May 12, 2011 Report Share Posted May 12, 2011 (edited) i was going to ask if it would be better to just burp or slow roll, or fast roll etc... Set it full tilt then pause it. When your ready to burp un-pause it. It will most likely take 3 seconds to blow the fuse if its going to do so. I saw a guy run a mmats not sure of model but it was a 4kwatt on a 60 amp fuse for 4 seconds before it blew. Also tones are best for burps encase you didnt know that. Edited May 12, 2011 by TIG Quote Since were all having a moment of truth. I hate country too.. I'd only listen to it if I got some hotass bitch in my car and shes gonna suck my dick. Link to comment Share on other sites More sharing options...
ALPINE408 Posted May 12, 2011 Report Share Posted May 12, 2011 i have a lot of expeance in this med roll is the way to go so your box rise will help not blow the fuse or you can lisen to the guy who "saw a guy" Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
OrionStang Posted May 12, 2011 Author Report Share Posted May 12, 2011 i have a lot of expeance in this med roll is the way to go so your box rise will help not blow the fuse or you can lisen to the guy who "saw a guy" So lots of practice runs, huh? Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
TIG Posted May 12, 2011 Report Share Posted May 12, 2011 i have a lot of expeance in this med roll is the way to go so your box rise will help not blow the fuse or you can lisen to the guy who "saw a guy" I was in the same comp as him only I was running smaller power but still fused low. I do not medium roll and I have no issues. Best way to decide how to do it is get some fuses from 40 to 100 and test them full, medium ect... Just remember you dont have to run the entire 30 seconds. If you know where your kitting best on what track and what volume you can get your best score in the first 5 seconds. Quote Since were all having a moment of truth. I hate country too.. I'd only listen to it if I got some hotass bitch in my car and shes gonna suck my dick. Link to comment Share on other sites More sharing options...
