ok so i have a problem now. whenever i turn my key back to the acc position, my radio doesnt come on. windows, and everything else work like they should, but my radio doenst. i have absolutely no clue what it could be besides something in the ignition. but how? since everything else works.
is this a new problem has the unit been installed recently
it works fine when the truck is either in the on position or on. it started doing this maybe 2 months ago. id just like to listen to the radio without having the truck in the on position. and yes, it worked when i first installed the head unit, now it doesnt.
did you check all the fuses for acc/ign also fuses under the hood. what year is your truck? does it have a gmrc01 interface for the deck wiring? if all else fails just run your stereo ign wire down to your steering column under the dash and slder a connection to the 12 guage brown wire in the main ignition harness; just make sure you add fuse at that location
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
its a 97. i dont need an interface. and i didnt think it could be a fuse since everything else works, and the radio turns on whenever its on/in the on position. i guess i could check them though.
Have you pushed your power button when its on the acc position? I know its obvious but, ive had to push the power button before to get my old HU to turn on in the acc position.
2009 spring fling-iasca-rookie 1-Champion. 139.4db.
"I don't do enough, I just fool around
Ya'll can go to hell, how does that sound"~ Tech N9NE
4 15" Memphis. and 1 Big ass box. <-Sold to fund more power.
Kicker l5s
yea ive pushed the power button, and im taking the h.u. out to ground my rca's sometime this weekend. i soldered everything in the harnesses, so ill check and make sure the pin didnt fall out of the harness. this isnt too big of a problem, id just like to know what went wrong.
  • Who's Online   0 Members, 0 Anonymous, 4925 Guests (See full list)
