Id like to put a bigger speaker in the door. Should I do it or stick with stock hole?
I dont really wanna do glass. give me some suggestions. 2005 hyudai elentra.
Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
do you have stock in there? just stick with the stock size find a componet set in 5.25" it will make it alot easier if you wanna go bigger your gunna have to cut it up and make it fit :good:
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
I got pioneer in the door now but can hardly hear it, rms like 35watts. I dont mind cutting, but what about depth.
measure the amount of depth you have to play with, then shop around, most of the time the mounting depth is in the specs
rockford makes some shallow mount mids/highs
Cars often have room between the door itself and the door panel; spacer rings can get you the depth you need for larger drivers, and no glassing required.
Big 3 with 1/0 welding cable, dual runs of 1/0 and 2gua F-R
DD 2512 D2 powered by Audioque 1200d at 1ohm, 2.5ft^3 ported to 36Hz
Boston SX 6.0 comps powered by Phoenix Gold M50 for front stage
Silver Flute 8" midbass in doors powered by Alpine 3539
Alpine CDA-117 HU
Spacer yes sounds good.
Guest grim83
check out cadence zrs 5.25 components theyre like 50 bucks and can get decently loud
Do you have a amp for the speakers? :)
yaeh a 4 ch zapco 380i i
think
  • Who's Online   0 Members, 0 Anonymous, 1597 Guests (See full list)
