For some reason my Fi's are no where near what they used to be. Now when I turn my bass knob up just a little bit, something in the system freaks out and the subs react chaotically. It doesn't even seem like it is clipping or anything. The subs will be playing at a nice sine wave at low power and then I'll turn it a little more and it freaks out.
Today I:
Tried playing some sine waves to see if it were from the songs I have been playing but it still did the same thing.
Tried it without the knob and used the volume for bass...same thing
Adjusted the gain...still the same at 1/4 gain
Checked the coils...they're fine
All the connections are good too
I don't what the problem is And if I can't figure it out I might sell everything because I could use the $.
If anyone could help I would Greatly appreciate it.
"IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Powermaster S3400 & D3100
Iraggi 300a alt
SecondSkin - totally dead
Knu wire
Did you try playing it without the bass knob?
Yeah. I even tried switching to my new Sundown knob and still to no avail.
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Iraggi 300a alt
Knu wire
Got any other decks you could try, i had a deck do that... was fine at low volume... turn it up and subs would go crazu
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
x2 i have also seen this happen a few times. this is what i would try next if i was you OP.
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
No other decks. I could probably play straight from my iphone but it probably wouldn't play much at all because itis most likely a very low voltage output.
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Iraggi 300a alt
Knu wire
they make an rca cord, that had a 3.5mm end, on one end and normal rcas on the other try that but start with your volume down and slowly turn it up
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
did you take the subs out to see if all the connections are good? you could have a loose one in there and when they start moving, the wires start trying to do some funky shit...
but i do agree, its like 8 bucks at radio shack.. 3.5mm to rca males, should be fine to test at the amp with it
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
Still does it on the iphone, though it was still slightly louder. Excursion only get to about 3/8" - 1/2" before it starts. Could it be something to do with current draw? But my voltage doesn't drop down?
Also what will happen if you don't back down on the knob/volume is that the amp will go into protection mode or something and the subs will make this slow rhythmic chirping sound. But when this happens the protection light doesn't come on, but the power light dims and brightens with the same rhythm.
What is going on? Does this sound familiar to anyone?
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Iraggi 300a alt
Knu wire
check your grounds... if the power light is flashing you could have a connection issue, power and grounds, please check them and double check them :P
Team DC Audio
  • Who's Online   0 Members, 0 Anonymous, 2783 Guests (See full list)
