so about a month ago, I was driving along just fine bumpin decently and the sub started cutting in and and out so I turned it off. Checked connections and tried to play again, it played slightly for a sec and cut off again. I turned it off and until today didnt know what happened. Everything was fine for about a month straight.
Anyway. the former came straight out the coil was stuck in the motor the tinsel leads were stick intact. I had to pull the coil out by the wire as shown in the first pic. So my guess is the coil came off the former due to glue failure, got stuck in the motor and blew up.
I measured the gap in order for Forevabumpin to see if he can get me a recone kit. I hope the measurement is good enuff. I could take off the basket if needed to better measure however I dont know if its glued on...
anyway I was like Dayum hopefully Foreva has a coil that'll fit :P
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
haha thats awful bro i feel you tho on blowin subs
NEW
2011 Chevrolet Silverado LTZ
2 XS Power D3400
Kicker HyperFlex 1/0
Soundstream Vir 7870bt
OLD
2010 Jeep Patriot
2 Murdered Out Black DC LVL 4 15s With XL Recones(with 1 extra spider pack a piece)
1 Crescendo BC 3500
1 MB Quart 60.4
1 Set RF T1 6x9s Up Front
1 XS Power D3400(Front)
1 XS Power D3400(Back)
2 runs of 1/0 Kicker Hyperflex
SoundStream Vir 7870bt
Fat Mat Rattle Trap Xtreme
[www.youtube.com/tntravelers33]
FEEDBACK
Nice motor. What is the coil inside dimension? The motor gap is mainly measured inside coil dimension and coil outside but I guess in this case its a little hard with the wire un wound lol. Measure the pole piece too. That will give me a good idea on what coil to use.
Was it a 4 layer or 8 layer coil?
hey sorry for the late response I was just looking for a pm notification in the corner and continued to other sites when i didnt see one. Umm as far as coil winding.. no idea.
i took this stupid pic just to confirm its a 3" coil. but ill get on trying to get you what you need asap tomarrow.
Setup:
Xs D3400/ Xs XP3000
Ok ima post some pics here in a sec. frankly they may not be all that helpful. but its the best i can do as of right now.
The motor bolts are glued in so removing them would be a pita. as far as removing the spider pack, should i be concerned with trying to keep the spider ring? (the plastic ring surrounding the spider pack that bolts down).
Setup:
Xs D3400/ Xs XP3000
pole piece outer dia
again outer pole piece
outer gap dia 3.2x"
i tried to get a better measurement this way
outer 3.12"
inner 2.90"
outer gap measured in mm for greater resolution
outer pole piece again in mm
again these pix might be useless to you idk, but ima call bob @ AB and see if he wont gimme the #'s. He prolly doesnt know em though but it worth a shot
Edited by P4killer_
Setup:
Xs D3400/ Xs XP3000
Well apparently Ab just got cones in, but if you can put something together for me id be happy to send the $$$ your way (foreva) so lemme know
Setup:
Xs D3400/ Xs XP3000
what kinda power u have on them??
oh never mind is see now
Edited by corrie32
i love this sh--t man 1966 Ford Fairlane Pioneer prs 80, the big three, with 2 big azz agm batts, dual 270/200 amp alts , two 8'' mids and tweets in the kick( PPI phantom 600.2). two 10''s and tweets in the doors, two 10'' mids and tweets in the rear decK ( Lanar opti 500x2). 2 C2 Audio Threatcon 4 12s on a Crunch GP3000d. No crossover .
