so i designed a box for my fi q 18. its 7.1 cu f before displacement which is .25 or something close to that. this is going to be a sub up port back setup.
using 3/4 inch mdf
dimensions
34 width 14 height 32 deep (inches)
Port
6 wide 12.5 high 24 long (inches) port area is 75" is that a good number. and i feel like 6 inches wide is really big. will i be ok? Someone told me i should have at least 80^2 of port area but to achieve that my port has to be 6.5 inches wide and i feel like 6 is already to big so i thought i'd ask.
alternate Port with *81^2
6.5 wide 12.5 high 26.35 long
also do you think i need internal bracing? if so where, how, and what kind?
look at my super internets it beast!
http://speedtest.net/result/906958776.png
this is my box i just made for my fi bl 18. without bracing it with mdf
heres the dimensions of the box. almost the same as what you want.
(UNDER CONSTRUCTION)
Kenwood KIV-700 headunit
2 18" sundown Z.v3s
13.5^3 wall tuned @ 28hz
SAZ-3500
DC power 270amp alt
JL c2 650
AP600.4
XS 1200 under the hood
XS 3100 in the trunk
1/0 gauge
big 3
25^2ft audio technix
^^ c-fuzzy ur an idiot, my 15" soround is waay bigger cuz its a tall sorround, on top of that I HAVE A BIGGER MOTOR... oh yeah and fuck u suck my dick i got your hoes!
anywhere they want to. They cant hear anyone telling them otherwise. just because its bigger doesnt make it any different. they just piss people off faster and farther away.
im adding a second baffle tomorrow and i will make a video of it to show the difference. you need bracing depending on what power you are running. im running a saz-1500 and i NEEEDD bracing.
2 18" sundown Z.v3s
SAZ-3500
DC power 270amp alt
JL c2 650
AP600.4
1/0 gauge
big 3
i'll be running a aq1200 if that helps
well i've got this 1" board of mdf that i could add as a second baffle i'm pretty sure there is enough wood. would that be enough ?
Edited by greatblack
yes
2 18" sundown Z.v3s
SAZ-3500
DC power 270amp alt
JL c2 650
AP600.4
1/0 gauge
big 3
Its actually going to be alot wider if you use 14-16 cubic inches per foot. Your looking at 99-140 inches of port area.
Remember an 18 moves alot of air so a big port is ok
Big 3 with Yellow Top
i get that but whenever i see boxes i never see the port being more then maybe 4 inches wide. am i calculating port area right? Port h*w
