Saturday I installed two sets of Polk Audio MM6501's in my Mega cab. I have a Kenwood KIV-700 and MB Quart 4.80 here's my problem I turn my HU up all the way and start turning up the gain on the 4.80 till it sounds good (about 1/8)but the tweeters are sawing my ears off so I switch the x-over from 0 to -3db and that helps a lot but they are still ear piercing. I have the frequencies at 150hz on the amp and HU I tried at 80hz no such luck. Some songs turned up all the way the tweeters start crackling they are flush mounted on the door panel. Anyone have any ideas on what the F is going on here?
07' 6.7 mega cab
H&S mini maxx
DPF/EGR delete
5" TBE
4.5" Fabtech
35" nittio trail grapplers
20" BMF novakane's
Kenwood KIV-700
Rockford Fosgate T1500-1bdCP
2-MB Quart 4.80
3-Polk Audio MM6501
ProBox DMC212L-1000 144db @45hz
Viper 5901
DAQ but how can I put more power to my mids with out hitting the tweeters with more power
07' 6.7 mega cab
H&S mini maxx
DPF/EGR delete
5" TBE
4.5" Fabtech
20" BMF novakane's
Kenwood KIV-700
2-MB Quart 4.80
3-Polk Audio MM6501
Viper 5901
First problem is you having the H/U all the way up, you should have it at 70% and anything more there is a good chance it will start clipping depending on the H/U manufacturer. Now you can start to adjust the gain to match the output voltage of the H/U as best you if you don't have access to an o-scope.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
How much does it cost to have a shop o-scope, I live about 3 hrs from the nearest and is it worth the time and $$ to have it done and would I notice the difference?
07' 6.7 mega cab
H&S mini maxx
DPF/EGR delete
5" TBE
4.5" Fabtech
20" BMF novakane's
Kenwood KIV-700
2-MB Quart 4.80
3-Polk Audio MM6501
Viper 5901
If the H/U has 2v pre-outs then you'll want to try and match that to the amp, if the amp has .2v to 6v adjustment then take a guess on where the 2v position would be and adjust to that and back it down a tad and that should be close enough without hard clipping it. The difference is not having a clipped signal ruining your sound and equipment.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Most shops do not have scopes. If you find one that does, move closer to it.
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
the problem is the tweeters and x overs, you can't turn them down enough to get them not to sound bright
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Thanks for all the info guys, I am sure I will get used to the full sound of the components over the full range Polks I had. I was hoping on maybe some breaking in time to balance out or something, I think I'll take the advice and back off the gain some cause that is where it seems to sound the best. I guess I expected a lot more outta the MM6501's they don't keep up with the two 12" I have at all.
07' 6.7 mega cab
H&S mini maxx
DPF/EGR delete
5" TBE
4.5" Fabtech
20" BMF novakane's
Kenwood KIV-700
2-MB Quart 4.80
3-Polk Audio MM6501
Viper 5901
you can help it by aiming tweeters in a different location try facing them at windshield if you can
