ALPINE408 Posted May 21, 2011 Report Share Posted May 21, 2011 check out the kintic 16v's no isolator or step down needed Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
dohckiller808 Posted May 21, 2011 Author Report Share Posted May 21, 2011 how would i run my 12 volt without a step down? Quote Link to comment Share on other sites More sharing options...
dohckiller808 Posted May 21, 2011 Author Report Share Posted May 21, 2011 ok just looked at the site. so i simply use the 12 volt post to run my 12 volt system? this seems very feasible. Quote Link to comment Share on other sites More sharing options...
dohckiller808 Posted May 21, 2011 Author Report Share Posted May 21, 2011 hay team bassick what part of cali do you live? shitty thing is im in honolulu so i would need batteries boated over using aloha freight located in compton. Quote Link to comment Share on other sites More sharing options...
SounDigital Posted May 29, 2011 Report Share Posted May 29, 2011 I'd stay on 12V for daily/bass race. Quote Link to comment Share on other sites More sharing options...
dereileak Posted May 29, 2011 Report Share Posted May 29, 2011 i dunno. i see guys pulling 10volt on 12 volt set ups all day. i know its not good. talking to some battery manufactures they say running the battery down like that is shortening the life of the battery but technically its ok on deep cycles. back on the 16v topic. i have a 01 sequoia so dual alts wont happen. i have a 300amp mechman in there now but i rely on battery bank due to no way in hell am i fitting another alt in there. im going to have to isolate and step down the voltage for the rest of mt 12 volt system. for that is why my concern is voltage drop. On Top of that, when your voltage drops that low, your amps become really inefficient, so they are trying to push more power out of them and they are just really pulling more amps and not getting much more power at all, just heating up the amps and wasting energy, if your voltage drops that low you need to get another alt in there or something, unless your running your system only on batteries where the engine is off, or some comp like that, then there is nothing you can really do, except get some 14v batteries ha ha Quote 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments) Link to comment Share on other sites More sharing options...
Tebo Posted May 29, 2011 Report Share Posted May 29, 2011 why not run 14v? Quote 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator Link to comment Share on other sites More sharing options...
dereileak Posted May 29, 2011 Report Share Posted May 29, 2011 why not run 14v? Yea, I would probably do a 14v system, you can sometimes maybe get by without a step down, but its kinda hard on your cars electronics, since they are all designed to run in the 12v range, but many will go up to around 15 volts fine, but with a 14v charging system it will have to charge higher then that Quote 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments) Link to comment Share on other sites More sharing options...
iKidwell Posted May 29, 2011 Report Share Posted May 29, 2011 I'd stay on 12V for daily/bass race. he speaks /thread Quote c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old. i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer. 2003 Infiniti G35 Sport Sedan Build in Progress Link to comment Share on other sites More sharing options...
