I have a a 15 inch Memphis sub woofer dual coiled. I have 2 older amps, one of the two amps I have been using both channels to power the sub woofer. I want to hook up a older profile amp to the sub along with the other one to power two amps to one sub, how will I go about doing this?
You have to have 2 identical amps.
Not recommended for daily drivers unless you have experience.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Why are you useing 2 channels of an amp to power one sub?
100x2 at 2 ohm stereo = 200x1 at 4 ohm bridged.
Because I have a dual coiled subwoofer that uses 2 channels
[/quote
:Facepalm:
A dual VC subwoofer doesnt need to be powered by two channels. You can wire the coild in series or parallel and run the whole thing off a monoblock amp.
Big 3 with Yellow Top
Because of you saying this, I would not recommend that you should attempt running 2 amps to one sub.
You need to identical amps and you have to gain match the amps so they put out equal power.
You bridge the 2 channel amp
watch the video that Steve did about gain settings. Good luck
:shrug:
Does this smell funny to you? Its your sister :roflmao:
LOL if he knew how to search the forum he could find the info he wants.
I know because I have written about it a few times.
