That would work fine, just set gains properly and make sure you have the electrical to support the 2k. Pm CJ18 or Dwright27 for pricing.
What kind of electrical setup would I need to run The 2? And thank you!
I'm running my DC2k on stock alt with one D3400 under the hood. Big 3, everything in 0gauge. Lowest I've dropped is 13.6v
You wont need much to be honest, a high output alternator(250A) and single good battery should keep up
I'm Gunna go with a kinetic batt...which one would work best with this setup?
U got a battery in the back too? Or just the one in the front?
Posted (edited)
I'd highly suggest a XS Power battery mate... But if your stuck on Kinetik, I would do an 1800 up front and another in the back.
I only have one battery up front :)
Can't afford a second battery LOL
Edited by Supercharged DDs
Haha alright thanks man :) will the battery u have work fine for the front without needing one in the back? Thanks man
It depends on the size of you stock alternator. Mine is a 117A, which is pretty big for stock. I would suggest a second small battery in the back just to be certain your proving sufficient power to the amp.
