Integra_boomer Posted May 30, 2011 Report Posted May 30, 2011 what are the specs on the new bc3500? cant find them anywhere. 1995 Integra GSR (DB8) Pioneer 3200-DVD 6.5 rockford fosgate 2-way fronts 6.5 rockford fosgate 3-way rear saz-3000D (2) 12" SA-12s
crunkjuice1 Posted May 30, 2011 Report Posted May 30, 2011 what are the specs on the new bc3500? cant find them anywhere. Specs 1ohm stable digital monoblock amplifiers Two amplifiers linked to 2ohm Frequency response : 10Hz - 270Hz Signal to noise ratio : 95dB Damping factor : 450< Input sensitivity : 6v - 0.2v Low pass filter : 35Hz - 250Hz @ 24dB / Oct Subsonic filter : 10Hz - 50Hz @ 24dB / Oct Bass boost : 0 - 9dB @ 45Hz Phase : 0 - 180 degree Master/slave connection (strappable to 2ohm) Remote level control level is included 0 gauge power and ground terminals Working voltage : BC2000D, BC3500D, and BC5500D : 8.5v - 18v External fuses rate : BC2000D : 200A (400A for linked) : BC3500D :>300A (>600A for linked) : BC5500D :>500A (>1000A for linked) RMS output power BC2000D : 2000 watts at 1ohm RMS or 4000 watts strappable at 2ohm BC3500D : 3500 watts at 1ohm RMS or 7000 watts strappable at 2ohms BC5500D : 5500 watts at 1ohm RMS or 11,000 watts strappable at 2ohm.
Integra_boomer Posted May 31, 2011 Report Posted May 31, 2011 what are the specs on the new bc3500? cant find them anywhere. Specs 1ohm stable digital monoblock amplifiers Two amplifiers linked to 2ohm Frequency response : 10Hz - 270Hz Signal to noise ratio : 95dB Damping factor : 450< Input sensitivity : 6v - 0.2v Low pass filter : 35Hz - 250Hz @ 24dB / Oct Subsonic filter : 10Hz - 50Hz @ 24dB / Oct Bass boost : 0 - 9dB @ 45Hz Phase : 0 - 180 degree Master/slave connection (strappable to 2ohm) Remote level control level is included 0 gauge power and ground terminals Working voltage : BC2000D, BC3500D, and BC5500D : 8.5v - 18v External fuses rate : BC2000D : 200A (400A for linked) : BC3500D :>300A (>600A for linked) : BC5500D :>500A (>1000A for linked) RMS output power BC2000D : 2000 watts at 1ohm RMS or 4000 watts strappable at 2ohm BC3500D : 3500 watts at 1ohm RMS or 7000 watts strappable at 2ohms BC5500D : 5500 watts at 1ohm RMS or 11,000 watts strappable at 2ohm. 2500rms @ .5ohm?? is that because the drop in voltage? 1995 Integra GSR (DB8) Pioneer 3200-DVD 6.5 rockford fosgate 2-way fronts 6.5 rockford fosgate 3-way rear saz-3000D (2) 12" SA-12s
BeatBox Posted May 31, 2011 Report Posted May 31, 2011 saw this video a wk or so ago on caco i got the 5500 myself, they look sweet and do have some weight to it glad u liked it, makes me exited to get mine running
tlee2 Posted May 31, 2011 Report Posted May 31, 2011 ^^^2500@ .5 ohm because of box rise 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
thericanballer Posted June 1, 2011 Author Report Posted June 1, 2011 ^^^2500@ .5 ohm because of box rise this
