People say 1500RMS is fine on stock electrical
I did all that and get a sub with better cooling? that makes no sense they have power handling for a reason... I shouldnt need a better sub to run rated. If this doesnt run 1500RMS dave owes me $450 lol Im not gonna run a BTL to get 1500RMS just because it can take a 1500RMS clipped signal without getting warm... I bought a 1500RMS sub for 1500RMS i can only say this so much lol
Im not even gonan question my woofer anymore I know its rated it can handle it easy its something in the setup or electrical that ive missed what COULD cause this thats not related to my subwoofer?
Grand Cherokee
Team Backwoods Bumpers
DC 15" Level 3's /w 4 Coils
Pioneer deh4200ub
Pioneer 3-ways
Pioneer Tweeters
Pioneer GM-D9500F
Audiopipe 1500.1D @ 14.4v
Clarion Equalizer
Knuconeptz Kollosus 0ga
Knuconpetz Kollosus 4ga
Coming Soon: 270xp / xs1200
I posted other things about electrical.
other things might be shitty ground, bad power wire, bad connections
as to the sub.. not all power ratings are perfectly true...
i didnt read all the posts, but have you even checked what your voltage is playing full tilt? at the alt, batt, and amp? test each one to see how your voltage is and to see if one is lower than the others.
you might also wanna try to run a ground wire along with the power wire back to the amp.
That was before man havnt updated my sig I was gonna get one for my bday cause i needed an alt but didnt... I have checked voltage its 13.2 at lowest accross the board sometimes 12.5 at the lowest idle. and Dave from PSI built and tested it he says it does 1600RMS daily and im running 1500RMS or less so you're saying Dave who built my subwoofer is a LIAR and his tests were lies?
But Ill try some suggestions and report back tommorow keep em coming guys...
Grand Cherokee
Pioneer deh4200ub
Pioneer 3-ways
Pioneer Tweeters
Pioneer GM-D9500F
Clarion Equalizer
Plain and simple if you are getting the woofer hot, you are likely clipping the shit out of it. Where is your bass boost set at and all your filters. And the power handling number is great, but really doesn't mean shit, if you are clipping it hard.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
I agree whcih is why I said i think im clipping lol... Subsonic is set to 30. LPF is set to 80 everything is flat man bass is 0 i never use bass boost Honestly though I cant read my amplifier too well theres only a min and max one ach setting so I put LPF at half and Subsonic at 1/4. I dont even have a bass knob lol amplifier gain is less than half of half...
Grand Cherokee
Pioneer deh4200ub
Pioneer 3-ways
Pioneer Tweeters
Pioneer GM-D9500F
Clarion Equalizer
How do I check my grounds with a DMM so I can check my battery ground AND amplifier ground.
Grand Cherokee
Pioneer deh4200ub
Pioneer 3-ways
Pioneer Tweeters
Pioneer GM-D9500F
Clarion Equalizer
You dont check grounds with a DMM. You either did them right or wrong..
What is your box tuned at? Fs of the sub means nothing about how low you can play if your box is tuned to 50hz..
Hammerdown... 1%
I've said a million times that im tuned to 27hz sorry if you missed it. My subwoofer was made to play low trust me ill post specs if u want. and you can check grounds with a DMM i just forget how.
Revc = 3.1157 ohms
Fms = 22.1886 Hz
Zmax = 29.4964 ohms
Qes = 0.5296
Qms = 4.4843
Qts = 0.4737
Le = 3.5576 mH (at 1 kHz)
Diam = 393.7000 mm ( 15.5000 in )
Sd =121736.4743 mm^2(188.6919 in^2)
Vas = 232.4022 L ( 8.2072 ft^3)
BL = 19.5513 N/A
Mms = 466.0655 g
Cms = 110.3911 uM/N
Kms = 9058.6992 N/M
Rms = 14.4899 R mechanical
Efficiency = 0.4504 %
Sensitivity= 88.5543 dB @1W/1m
Sensitivity= 92.6497 dB @2.83Vrms/1m
Woofer specs:
5.0 @ 34hz recommended
1600wrms
SQL Daily
Dual 2 OHM
18" 6 Spoke Basket
4 Layer Extended Aluminum Roundwire Voice Coil
3 8" Progressive Soft Spiders
10GA Direct Leads
Single Sewn Lead Wire
6" Poly Dome Dustcap
Thats all my subs specs right there.
Grand Cherokee
Pioneer deh4200ub
Pioneer 3-ways
Pioneer Tweeters
Pioneer GM-D9500F
Clarion Equalizer
Also what size is the speaker wire going to this sub? And you CAN check grounds with a DMM.
DMM set to DC voltage
Step 1 - Place meter pos lead on pos stud of battery, neg lead on neg stud of battery, record reading
Step 2 - Leave pos lead on pos stud of battery or amp 12v+ and move neg lead to your grounding locations, this reading should be same as reading in step one
Step 3 - If step 2 is more then .5 volt difference then step 1, bad connection point, so make it better
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 1067 Guests (See full list)
