Is my stock 109 amp alt enough to charge and maintain a second battery? Or would I be better off upgrading my alt then adding a battery?
My Current Project: 2006 Ford Focus ST
HU: Kenwood KDC-X986
Amps: Rockford Fosgate R300-4
Hifonics Brutus BXi 1601D
Sub(s): (2) Skar VVX8 want to add 2x
Mids/Highs: VXI65 components (front doors), RE Pro 5x7FR (rear doors)
Wiring: Big 3 done in Candace 1/0 awg.
1 run from battery to distro-block 1/0 awg. Cadance wire
4 awg Stinger wire from distro-block to amps.
Electrical: stock alt.
Optima Red Top.
What batteries are you going to run? What size wire? Big 3 done?
Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
BXi 1601D Hifonics 1600 watts at 1ohm. And another 400 watts from an old school RF Punch.
Optima Red Top.
Big three is going in first with 0 awg. Looking to run 0 awg from battery to distro block then 4 awg to amps.
Optima Red Top.
As far as the extra battery, I don't know what type. I just want to know if 109 amps is enough to even maintain two batteries with approximately ~2000 watts rms? Is it possible?
Optima Red Top.
You might be able to get away with it if you don't listen to your system at full tilt often. With those two amps, assuming that they can put out 2000watts rms that will draw about 166 amps of current. If you exceed the amperage rating of your alt by more than 20% you can expect to have problems. 20% of 109 equals about 131 amps. And that is all assuming that you are going to be playing it at full tilt with your car not demanding any other electrical needs.
I wouldn't want to do it but if you decide to the extra battery will help for sure but it would be good to replace your alt
Thank you to all who replied! I really lime the info and help I receive on this forum. I rarely turn my system up past half way. I'm not trying to impress anybody. I just like my music to be clear and clean.
Optima Red Top.
