wats goood
everyone is been telllin me to get another pa3400..
but i have a question bout how to hook it up..
i have 5 subs..and all the subs are wired up to one wire to to the amp..
how would i wire the second amp?
5 15" american bass xd's in a wall
18 cubic ft ported boxx..
1 pa sl3400 for subs
all 0gauge
3 duralast batts
workin on the mids n highs
"Bend My Hat Back Knockin Down Pictures Off Ya Wall
big murt Comin Hard,
Beatin Hard In The Drop Top.
Old School Chevy's Color Candy Call It Lollipop"
Are they d1s, d2s, or d4s? I don't know anything about AB stuff.
they are dx's and are single voice coil....
and my amp is a class d wich is one chanell
and the amp has the slave and master feature or watever...
all 0gauge
3 duralast batts
the amps are strapable..
and i think the subs are single 2 ohm...
but if i strap the amps do i jus run the both amps into the wire coming out from the box
all 0gauge
3 duralast batts
you THINK?? ive never heard of a single 2 ohm sub so hmmm questionable
i dont recommend 5 subs and 2 amps and strapping them. you should have an even number i would honestly cut one out and do 2 per amp that way you dont end up with a x.xx ohm load.
NoFearX18 said:
trainman0978 said:
who cares about a x.xx ohm load?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
true BUT if his amp is 2 ohm stable and you end up with a 1.34 it MAY put it into protect some amps are jsut that sensitive.
NoFearX18 said:
trainman0978 said:
I don't think having a x.xx ohm load is going to hurt things unless it's below the amp's stability capability. Those subs are most likely not single 2ohm, & if you have them all in parallel, That rules out single 4ohm also. Take one out & see for sure, that way we can tell you whatcha gotta do bro.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
I'm curious to know how you currently have 5 svc 2ohm subs wired to your amp. If they're all parallel thats a 0.4ohm load. If they're all in series then its a 10ohm load. If its 2 in series and 3 parallel or something of that sorts then they're all getting a different wattage. I'm really scratching my head on this one.
