Power Consumption/Alternator recommendation?
Ok, guys, small change. I would like to add one more McIntosh 300 watt amp for a total of 1000watts hooked up to a 15" JL Audio 13w6v2 sub.
Does this alter anything power wise? I will be doing the "Big three" of course and am planning on running one of the 3100 batts up front as well as one in the back by the amps. Zero gauge power and ground wires run to batts and amps.
Thanks again,
P.S. Tentative starting place for xover is the following:
15" sub -- 40hz and below
10" subs -- 40hz to 150hz
6.5" midbase -- 150hz - 750hz
4" mid -- 750hz to 10khz
tweets -- 10khz and up.
Edited by SQPunk
should be plenty of juice for 1000 watts :)
I'd hit that so fucking hard whoever pulled me out would be King of England.
Lol... looks like we were on the same page. Car-B-Ques suck.
ya, tires and paint burning make the marshmallows taste funny.
wait so you want to run 1 700w amp to the sub, and a 300w amp to the sub? if i read that right, dont do that....
seriously...
and you should be fine with that setup with the alt and batt you have
Team_DC-Derrick's Youtube
Team DC Audio
oh yeah then you are fine with your power...
Team DC Audio
My bad. It appears that the 13w6v2 is a 12" sub. I am going to have to look around more.
Sorry for the error.
Edit: The W0v2 15" sub looks promising. It will handle the power of the McIntosh amp nicely. I will have to go give these and others a listen before I make my final decision.
Cheers,
Edited by SQPunk
Thanks again,
Don't mean to thread jack but this caught my eye.
What mid do you plan to run that will play up to 10khz without breakup? Ive been looking into 4 in mids for my rebuild and for sq (which i assume you are going for since ur using McIntosh amps) i have found that very few mids sound that good/should be crossed above 5k. Im just curious what you have in mind!
To the original quesion tho, you will be fine with that small power. Depending how you listen to your system, i would say you could probably get away without the extra battery in the trunk. Just the stock alt, big three, and single 3100 up front
Team NorthWestSPL
So you use a 15 and 2 10 inch subs? :s
And you want SQ? I hope you can really make it blend in perfectly.
Just like mrd6 said, where can you find a mid that will do that kind of big range of frequencies? :peepwall:
  • Who's Online   0 Members, 0 Anonymous, 1827 Guests (See full list)
