Using a Full Range RCA for Sub Amp Bad?
IH8PunkRok
say you have a head unit that has no sub out but has an output that has all frequencies coming out of it. is it bad for a sub amp to get all those frequencies?
supposing the filters were set correctly and all
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
No.
Just filter it.
The amp isn't doing anything with the frequencies, they're filtered before amplified.
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
thought so
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
i just had to check because i have an amp that is doing some weird shit and im trying to rule everything out.
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
it is switching back and forth between protect and not.
i hooked it up to a different load and it still did it so i can assume the sub wasnt the issue. voltage isnt a problem. it isnt great but isnt sub 12s. it stays 13s normally
im thinking some internals got rattled loose as it is mounted on the face of the box where the sub is
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
I'd try to elminate possiblities by putting the amp on a bench connected only to a battery and the sub. If it doesn't do this out of the car, then the problem is in your electrical. If it does, I'd crack the case open and start looking for blown caps.
2007 Pacifica
easier said then done lol the car this amp is in has a trunk that makes mine look huge.
but yeha i get what you are saying. i gotta test every aspect to really know
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 1165 Guests (See full list)
