Make sure you have the gain lower than you normally would on the amp and if you electrical is up to par it will should be fine.
What makes them blow when running at a lower than recommended ohm load is overheating so you can add a fan on the back of it and/or leave the gain lower than normal. I would say do both...better safe than sorry.
I have 2 DC 3.5k amps strapped running at .4 ohm daily with no problems. the gains are love (about 25-30%) and there are fans on the back of each.
Hope this helps!
lulz
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
arggggghhhhhhhhhhhhhhhhh no no no no and no
a bd1500 is a 2 ohm rated amp
a t1500bd is 1 ohm rated and i still wouldnt do it. do you have electrical that is suited for double the rated current draw? Im going to say no. You probably have the rock em stock em electrical. Stop being cheap and buy power at the right load.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
