Posted (edited)
Heres the layout for now
alpine cda 105
clarion eq
4 18 fi n2's wired to 2ohm
-27cuft NET
-3 8" aero ports
-27hz tuning
2 crunch gp3000ds strapped
-subsonic set to about 20hz
problem is it doesnt play the lows as violent as it did with 1 amp 43-44hz(Sounds peaky compared to1 amp also) is loud but it kind of fades off below that..still moves some air but not like it did on 1 amp at .5ohm
Also i have to take a look at the slave amp for the settings(subsonic) but im pretty sure they wont matter since its in slave mode
Edited by Jextel
http://www.cardomain.com/ride/3042878
TEAM DEADLY HERTZ
"GET LOUD OR DIE TRYIN"only the loudest will survive.
I think your problem might be that you picked kick ass subs and weak amps.
Big 3 with Yellow Top
Depends, if they are 3000d-pros then they are very very very very solid amps...
im having weird problems strapping zenon 3ks also...just unstrap them is what it comes down too!
DCAUDIO
BALLS DEEP
So it's quieter with 2 amps? Maybe it has to do with the power vs. Box size??? We can try my 3500s on them one day if you want. Just run the wires from my car to your subs. Strapped vs unstrapped. Idk how you strap with those amps but make sure the impedance isn't going up with your wiring configuration.
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
its hard to say its like anything below 40hz isnt being played loud compared to 40hz and up is its definitely louder on that end but 40hz and lower just isnt there anymore on 2 amps
TEAM DEADLY HERTZ
very weird...so w 1 amp you had it at .5 with both amps your seeing a 2 ohm load? i know when you strap an amp you get more imp rise and/or power compression could come into play...i think for 4 18s you need MUCH more port area than 3 8" aeros and the extra power is actually putting to much power into the box and not letting it out making the subs fight their own back pressure killing the score and lows...you gotta figure a low note moves A LOT of air...if it cant get out quick enough the subs are gonna build up on their own pressure
NoFearX18 said:
trainman0978 said:
Posted (edited)
I rewired it for the strapping (series then parrallel)
Im not worry about the port area too much...(Didnt wanna use him as an example but look at steve meade lol) then again i have about 7cuft on his box..
Edited by Jextel
TEAM DEADLY HERTZ
  • Who's Online   0 Members, 1 Anonymous (See full list)
