blessedcoast206 Posted June 6, 2011 Report Share Posted June 6, 2011 Got a 96 ford Taurus with a fi btl 18 and it's flexing the rear window pretty bad. I only have it on 600watts and the window is already flexing an inch. What should I do? Cause I dont want any moisture issues. Quote Link to comment Share on other sites More sharing options...
egag Posted June 6, 2011 Report Share Posted June 6, 2011 downsize lmao Quote 1994 Jeep Cherokee !@#$%^&*(Soon to come)*&^%$#@! TONS AND TONS of Audio Technix 80Mil 1 x 270 Amp Mechman Alt 1 x AQ3500D.1 1 x Rockford Fosgate T600-4 8 x Rockford Fosgate T2652-S 2 x XS Power D3100 1 x XS Power D3400 1 x eKs Kable 2 Channel Silver Plated RCA 5M 1 x Knukonceptz Kolossus Fleks Kable 1/0 Red 50FT. 1 x Knukonceptz Kolossus Fleks Kable 1/0 Black 50FT. 4 x Avenue - A605 2 x Fi Q 18 Link to comment Share on other sites More sharing options...
cubs_fan0718 Posted June 6, 2011 Report Share Posted June 6, 2011 I would pull the back glass out and re-seal it using some heavy duty stuff. If you not willing to do that then ur going to have problems, and would be better off downsizing. Quote 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017 Link to comment Share on other sites More sharing options...
blessedcoast206 Posted June 6, 2011 Author Report Share Posted June 6, 2011 I would pull the back glass out and re-seal it using some heavy duty stuff. If you not willing to do that then ur going to have problems, and would be better off downsizing. what about some Plexiglas or something? Quote Link to comment Share on other sites More sharing options...
Louisiana Bass Posted June 6, 2011 Report Share Posted June 6, 2011 Plexiglass would work, but it's a bit pricey. Quote N8. No homo...unless you want there to be. Link to comment Share on other sites More sharing options...
cubs_fan0718 Posted June 6, 2011 Report Share Posted June 6, 2011 unless you got a thick ass peice the word plex ryhmes with flex, also it would have to be formed to ur back window and plexiglass scratches pretty easy. Quote 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017 Link to comment Share on other sites More sharing options...
blessedcoast206 Posted June 6, 2011 Author Report Share Posted June 6, 2011 Plexiglass would work, but it's a bit pricey. hmmmm....what else would work? Quote Link to comment Share on other sites More sharing options...
WillPwn4Food Posted June 6, 2011 Report Share Posted June 6, 2011 (edited) Use your sub till your window springs a leak, then reseal it. Or downsize. The Taurii do flex pretty bad. I've got an 02 that flexes with a simple 15". I guess that's what you get for having a cheap car. Do the 96's have the fold-down back seat, too? Edited June 6, 2011 by WillPwn4Food Quote Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893 real men dont use fuses Neither do moronsSays the guy with lambo doors on his Ford Taurus. Link to comment Share on other sites More sharing options...
Autruche Posted June 6, 2011 Report Share Posted June 6, 2011 How to stop your back window from flexing as much... Buy another 18 and wall it. No more pressure hitting the back window then. Quote Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want Link to comment Share on other sites More sharing options...
Bmike Posted June 7, 2011 Report Share Posted June 7, 2011 i had an issue like that in my accord , had a 18 btl and saz 3500, and there times when i thought the window was gonna go , this is how i fixed it, got a 1 foot long peice of angel alluminum and screwed it to both the box and the bottom of the dash where the window connects, heres a pic, its taken from the out side of the trunk. Quote 2007 trailblazer lthead unit- pioneer p4300dvd crescendo ft-1 supertweeters pioneer m650 pros audiocontrol 2xs crossover Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas Link to comment Share on other sites More sharing options...
