ok, rolla is gone and forgotten.
got new car and gonna get it hit hard.
it's a "Swedish Tank" VOLVO 245 GLE with 109bhp raw powaa!
equipment:
front: SPL Dynamics 4.2 4" woofer + 1" high's
back: Crunch FatboyII 300w rms 600w peak.
sofar starting the build with slim to none equipment. planning on playing front with 4chan amp and sub with 1 monoblock.
monoblock got potential up to 3000w with .5ohm, but don't have the cash for DC audio sub, so going first with 4ohm and 400-500w rms.
First day:
this baby has some ROOM! goddamnit!
checking how much space this one has.
back battery goes here.
amp's goes here, just enough space to fit 2 amps.
front battery will stay there, adding extra battery to back and setting up 200A fuse and Relay to keep em off together when car is off.
second day:
time to install headunit, it will be alpine 9880R
finding wires in front.
fixed new radio sockets with the old one.
check'd the front speakers with 1,5V battery. they will be connected into amp when ready.
end result pleased, works awsome.
the headunit did not fit well, had to use some FORCE :S
USB peaks out from original front speaker place (6x9)
hides well aswell.
end result looks fine!
Day three:
got some goodies from the post!
amps FITS! they FIT!
other box included 8" port for upcoming enclosure! it sure is big! and perfectly smooth!
more to come! installing wires today and frontspeakers ans sub tomorrow, perhaps!
im intrigued
continue
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
so, lets continue with this!
200A Fuse found itself at front.
This 50mm2 (0AWG) goes to back battery in the future.
wires went the normal way, trough firewall, down to floor, under the carpet to the back.
this one is from back where cables goes trough the chassis into the amp rack
here will amps be, the negative wire is only 8mm2 but it is only to remove negative potential between the two batteries, so the back battery will have more negative cables to the chassis.
next! ... PFFFFT >_>
took these from the pile:
3x RCA
2x 1mm2 (to Voltmeter from back battery to front)
1x 2mm2 (RMT to amps)
2x 2x1,5mm2 front speakers
cabeling has never been this easy, this car has ALOT room allaround the car.
pile of wires going towards the back.
two smallest wires to the battery -place, rest into the amp rack.
next! speakers to right!
now how should i squeeze trough this...
wait.... WTF is that!?
hohoho, one hand fists all... or what?
midwoofer connected
lookin guuud.
but then i noticed that something had struch the tweeter...
goddamnit :S
FFFFFF....
this is how i install xovers ;)
like that!
voila!
driver's side started with removing the fusebase.
behind that i found samekind of a hole like on the other side.
driver's side done!
xovers like the last one.
now that metal bar behind the headunit, it moves when the windscreen wipers moves, so it can slash my RCA:s like nothing ;S
i had to do something with that!
secured!
at the end of the day the trunk should have looked like this......
but it looks like this ;(
and last but not least, what will come later... should not take more than few months, i hope :(
8" port next to 12" Fatboii!
tomorrow, connecting sub and front speakers and do a testrun.
it will not whoot my windshield off, but it will be first subwoofer in this car!
I love Volvo wagons,I was going to Buy one that had a Ford V8 engine transplanted into it,but the guy decided tokeep it,damnit......Tuned in for this one
Does this smell funny to you? Its your sister :roflmao:
  • Who's Online   1 Member, 0 Anonymous, 618 Guests (See full list)
