SnowDrifter Posted June 6, 2011 Report Posted June 6, 2011 As some of you may or may not know, me and my friend were going to build a 4th order BP box for his 2 kicker comp 12s (2010). Then I read the post on t-line boxes and figured out how to design and build them. Now my question is: Should I put them in a t-line? I know the specs are a bit outside of what is reccomended, but I am wondering if it is still possible. Specs: Fs = 30 Qts = .559 Qms = 10.22 Qes = .591 ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SnowDrifter Posted June 11, 2011 Author Report Posted June 11, 2011 Bumpity bump ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
IH8PunkRok Posted June 11, 2011 Report Posted June 11, 2011 possible yeah -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
nCOMP1337 Posted June 11, 2011 Report Posted June 11, 2011 i dont think it would work well, except for the Fs, the other specs you listed are all higher then is recommended for a tline and not by a little, the qms is about 150% higher than suggested It may work, but it probably wouldnt give you the output you want, and the sub may not fair well in the environment some subs just arent made to work in certain applications when i decided on doing a tline, i did a lot of research finding what subs met the recommended suggested specs for a tline, i ended up on AA chaos, although one of these days want to do a tline with an IDQ as well either way best of luck bud
